Well at the risk of sounding like a broken record, I would Echo the thoughts that H has on this tube. Although I have not had a chance to try them as powers last night I did a lot of power tube rolling. Including the gec 6as7 and gec 6080 ts 5998 and my findings are that with the el12 Spez it is a much sweeter sounding tube than any of the other powers that I tried. So I would conclude that Synergy is going to be very important for this tube. I was using the straight-sided tube all last night and it is one sweet sounding tube. So if you cannot find any St tubes, grab some straight-sided tubes and not worry about it. Like H says from time to time the St tubes will make an appearance and when they do jump on them! And the next couple of days I'm going to try to compare the straight and St tubes one against the other but I have a feeling that is going to be very difficult. It's just not going to be obvious which one is the Stellar performer. I can hardly wait to get the adapters from mrs. X so I too can try powers and drivers I have a feeling that H is going to be right again. But then when is he ever wrong! And by the way h, you can put me down for two more adapters if you're still in the market to make these. I can wait no rush I know I have of two coming from mrs. X but I would just as soon have yours if I'm going to use all four. Not to mention they'll look a lot nicer having all for the same!
Hi cf.
Good to hear your findings so far, and that they confirm what my own ears/brain are telling me lol!...(still can't actually believe it/them!! ). It's especially encouraging to hear that you find the straight-sided tubes so good...keep up the good work, even though you must be needing an ear transplant soon!
Have just ordered some more Neotech UP-OCC solid silver and (solid) copper wires, so hope to have some more adapters under way very soon now - the top caps having (finally!) arrived. I won't even consider any other wire now...if it's good enough for Woo Audio's new $15,000 WA33 Elite, it's certainly good enough for me!!...although I always go by my own results anyway...So you're on the list for another pair lol!
And on the subject of comparison, I personally have found that it can indeed be very difficult to assess exact differences when two tubes are so similar - especially because of the time factor, when one lot need to cool down well before removal, and the next need time to warm up! Then the only real way to tell is proper fast A/B-ing, which requires TWO exact same systems running side-by-side...and who can manage that?!! And so I myself go more by using tracks that I've listened to literally hundreds of times, and looking for certain traits within each that must at least be present in the new tubes/gear, plus any extra that may come along...and not be lacking anything whatsoever from the previous 'best'. This can only come, of course, from tracks one knows very intimately...boring in one respect, but the best way of judging IMHO......CHEERS!...CJ
