Today my 20A voltage regulator arrived. The previous one I used was rated 15A but not strong enough to handle the Quarter Pounder power tubes - the Cetron 6336B.
https://www.ebay.com/itm/DC-300W-20...tep-Down-Converter-Voltage-Buck/222637386210?
hash=item33d638e9e2:g:K18AAOSw6Q1ZsRox
(There are many sellers - I paid $8.10 for mine and it arrived in a very short 12 days)
It appears that this voltage converter made a difference - the sound is improved. The prodigious bass is immediately noticeable.
So far I just tried it out with an eye on how hot the heat sinks get. The heat sinks are roughly twice as large as on my old 15A voltage regulator - 1" high, 3/8" thick and 1 3/4" wide. I put the converter near my 4" cooling fan, and the temperature does not exceed 100F and there is no danger in touching the heat sink fins (not something I can say about the 5A Cetrons).
The driver tubes are TFK EL11 - nice, vivid and impactful presentation, but need more time to arrive at conclusions.....
Have fun!
Wow Mordy, you're a die-hard innovator. I would really like to hear a comparison between Cetron 6336B vs. your other top chosen power tube setups, when you have time. No need for an in-depth analysis, just sound impressions the way you hear it... though if you can also include headphones for the comparison that would be super, because I'm finding some of your recent suggestions to sound different on headphones than you probably hear it using speakers.
PS - which adapter are you using? And I take it that setup plays nice with "Mr. Humphrey", right?
