connieflyer
- Aug 23, 2012
That I will brother from a different mother! Gee, I hope that is not offense to a moderator! I forgot how sensitive they can be!
I think I am done buying tubes for now, need to add to the game room decor, so since I don't have a basket hilt, I think I may order one of these. https://www.theknightshop.com/brass-basket-hilt-sword-ca-1700
Until you have used one, the fun is just not there!
Beside beautiful sound, tube audio gears could be tailored tube-rolled to fit one's preference.
I have just some questions.
After reading something about heat and octal socket savers. Do I need them for my Euforia?
Maybe not really a question, I read somewhere I should not insert the tubes completely into the sockets but leave a little room to get a screwdriver under it so I can always get the tubes out of the socket when they like the amp too much and hang on to it.
Are there more Tricks I need to know of?
Althalus
Contrary to pct, I have read that I believe on the Elise thread early last year. I believe a member had trouble removing a tube, and it was suggested to leave eniugh room to insert a small jewelers screwdriver under the tube to get it started out. I had only heard this if the socket was very tight, they do loosen up after awhile. Even the new sockets on my Euforia have loosened up some. They are not tight, just snug. Socket savers may help slightly for heat, mainly made to protect sockets from wear and tear. In all the years as a technician in the Navy,(tube era) I never had to replace a socket. Another consideration,you are puting another component in the circuit of unknown quality of construction.
