- Jun 26, 2012
It sounded similar to me compared with other 6SN7.
If you use 4xEL3N as power and you use 6SN7 or 6N7 there's a drop in gain.
You mean a drop in gain compared to 6 pack?
Yes. With 6 pack, gain is better than stock tubes. When I switch out EL3N drivers for 6SN7, 6N7G, gain drops. Switching to C3G is even worst. Above 12 noon, it induced hum.
There's something about using 4xEL3N as power tubes. A drop in gain with other drivers other than EL3N. I mentioned this a while back when I was testing the various combinations.
If the drop in gain is not a problem for you, it's ok.
Probably only 7-8 hours on the "six pack" - and wow!
If these take 100+ hours to reach their full potential I'm in for a real treat!
Initial impression of air and space are now opening up and getting more and more detail too.
I think I'm a bit of a detail freak - especially when it's not at all fatiguing.
Pulled a double shift at work today so will take tomorrow off (or at least work from home) and get another 12-14 hours on the EL3N's by tomorrow night.
I've watch @pctazhp in his early days loving the 6 pack. Then I heard @connieflyer and @HOWIE13 loving it with passion.
Now you....
Good to know I'm not alone in this universe.
That's a delicious combo Howie.
So you got the T1 G2. Nice.
Have you also had the T1G1 @HOWIE13?
Curious how they compare, especially via Elise.
