JazzVinyl
- Jan 7, 2010
I made an adapter myself an here you can have a pic with 6L6GC (same pinout as EL34) and 6N7GT. (the 6L6G is a less powerfull than EL34 and it is already a lot for T1).
The principle used for the adapter is :
OMG, Suuup....RIP Elise!!...
Here's a question for the techies...
I'm still facinated about the single triode 6C5G analogues of the twin triode 6N7G. Probably just because I fancy ST shaped tubes, can't have enough of them ... The replacement results in half the gain of course (mu of 20 instead of 40) . Looking at the Mu of the power tubes often used with the Elise below, it could provide a means to level the total gain when using powers with relativey high Mu - like the 5998. If net gain is the result of the multiplication of the Mu's of the driver and power tubes , the combined Mu of the combination of 6C5G and 5998 would be close to that of a 6N7G with 6AS7G.
5998 Mu = 5.4, Gm = 15500, Rplate = 350 ohms, Vplate max = 250 volts and Vplate max 5998A = 275V
6AS7G Mu = 2, Gm = 7000, Rplate = 280 ohms)
6080 Mu = 2, Gm = 6500-7000, Rplate = 280-300 ohms
Could that be an advantage in certain cases?
The output circuit is a cathode follower and has a gain of 1 actually less so there is no gain on the output tube.
Very cool, thanks for the info.
I still am curious about the EL34, maybe it can be used to drive the hard to drive headphones, especially hifiman's, good EL34s have a very good reputation and are not that expensive. Also keep there sweetspot consistent for in excess of 10.000 hrs. You would need to do some external heating for the power draw I imagine.
How are you liking the sound of the 6L6s? I assume like the EL series they require over 200h to properly burn in.
Cheers
WB
WOW!
WOW!
