The only headphone amplifier i know from icon audio is the HPA8 (650 BP) where the output tubes are 6SN7 it is already much less powerfull than 6AS7G/6080. About price you should keep in mind that Elise is very well positioned and if you want to get a better sounding amp it will cost much more.
You should not really compare speaker amplifier with OTL headphone amplifier as the design is not the same.
Thanks HPAMDR,
yeah the HPA8 is good and the most sold amp of theirs I know it and am curious how it sounds in comparison to the Elise. The Stereo 25MKII is also a headphone amp, and quite good at that, still a little intro and was designed as a means to get into tubes. I know the design will likely be quite different.
The Stereo MK40s have quite a nice sound and I might be looking into these for the HE-6 I can get inexpensively. Might also check out the Feliks PSE 2a3 but not sure if that would have enough power depending on how the Elise experience goes. Ideal would be more than 8W at 50Ohms.
Seems as if a little bit of money is coming my way, so a nice speaker tube amp might be the next purchase.
All said and done I do very much like their 2a3s, EL34 and EL84 models soundwise, while not being excessively expensive and readily available (to audition) in Europe.
Cheers WB
