Groove:
[VIDEO]https://www.youtube.com/watch?v=U43-rXCRlz8[/VIDEO]
You will still need a 9 pin to 8 pin adapter with that one.
This one will work.
http://www.ebay.com/itm/1pc-Gold-plated-12AU7-12AX7-to-6SL7-6SN7-tube-converter-adapter-/201320842633?hash=item2edfa84589:g:ge4AAOSw~gRVuNUb
Cheers,Glenn. I must have been editing my post to include that one just as you were typing your reply.
Appreciate your help. No idea if E80CC will work but I'll give it a try-it's a favourite tube in my Garage amps, especially for vocals.
It looks like the 12A(T,U,V,X)7 class tubes are generally not compatible in the Elise's 6SN7 driver tube slot. However there are 6 volt versions (the ones with parallel wiring) which should definitely work, though needing their own adapter. This data sheet shows the voltage / heater current for both serial and parallel versions of these tubes:
http://www.mif.pg.gda.pl/homepages/frank/sheets/093/1/12AT7.pdf
Also I've read glowing reviews of the performance of the smaller 6FQ7 tubes, notably in their soundstage. These are the successor of the 6CG7 which are both interchangeable, have identical voltage specs as the 6SN7, yet need their own adapter. No problemo, gold ones here are on the cheap.
Helpful read here:
http://www.effectrode.com/signal-tubes/the-6sn7gt-the-best-general-purpose-dual-triode/
Hi DL,
If you look into the Little Dot tube rolling thread you will find a huge amount of information on the miniature tubes. Since you are in discovery mode, why not try some sub miniature dual triode tubes designed for ballistic missiles - can withstand 500 G.
This picture is of the Raytheon 6932 - a better sounding one is the Sylvania 7963. There are Russian versions as well.
IMHO these classes of tubes do not sound as good as the octal drivers people have tried on this forum, not to mention the EL3N and similar tubes.
Another miniature tube that sounds quite good is the 5687 but it has a different pin-out than the others.
Shuguang Treasure CV181-Z. These look to be some outstanding performers, and finally we would get an ST-shaped driver tube, as these are a 6SN7 replacement. I think anyone considering this should put aside any bias against Chinese made products - after all HiFiman is Chinese too. I'm personally not going this route yet, but would love to hear from anyone who might take the plunge on this one for the Elise, and I'm sure your ears will thank you too!
