a local is generous enough to give me a commerical version of kgss from headamp for a week to compare with the exstata.
setup for comparison is:
buffalo dac balance out to exstata
buffalo dac single end out to kgss
(did comparison first between buffalo balance/single end out to kgss to make sure there's not difference between the two)
headphone is o2.
listen to one track first on one amp, switch over to the other amp, repeat the the track.
one most obvious different when switching over from kgss to exstata is: exstata little better resolution. imaging is crisper, sharper, better focus, better defined.
soundstage is a bit wider with the exstata, there 's a bit more space
between instruments.
kgss sound warmer, laid back, exstata has faster attack and transient response.
vocal is more forward in kgss, vocal in exstata sound a rew row further back but without lost of detail and focus.
can't tell much different on bass between the two, may be bass in exstata is a bit leaner and tigher with better texture and definiton.
treble has better extension on the exstata, revelation of micro detail in this area is better.
i like to say thanks again to the indiviual who let me borrow his kgss for a week.when i first built the exstata i thought it's very good, but have no idea how good it is in compare to other well known electrostatic amp ( the only full size eletrostatia amp i had heard at the time is the little known chinese diy 8ps amp mr he built for me)
the kgss enbale me to set a benchmark and compare the exstata with.
i am extremely happy with my exstata, it only cost me $450 aud all up ( about $400 usd at the time of currency exchange), a Significance saving. thanks alex for bringing us this amp.
some obseration of the kgss, it run very hot, i can feel the heat on my hand through the vent on the case. dc offset is over 8v on startup and it take over 20 minutes for the dc offset to drop below 1v.
