minivan
- Jun 15, 2007
Originally Posted by minivan /img/forum/go_quote.gif just fired up my ss version last night, very good detail with good extension on both end. ]Imageshack - estatass - Uploaded by triseven |
Originally Posted by BoilermakerFan /img/forum/go_quote.gif OK, I cleared up the schematic for the PVA preamp attenuator: |
The 1:2 PVA transformers are $55 each from E-P. So for under $150 I have a pretty nice preamp attenuator. |
Originally Posted by digger945 /img/forum/go_quote.gif Are the 5k's really necessary? The reason I ask is because I dunno I was thinking we would see something where the only resistance was in the shunt element of the circuit. I'll be trying this soon to listen for meself. Already have some transformers, just need some time. |
Originally Posted by pabbi1 /img/forum/go_quote.gif Ok, found my psu faux pas... well, at least the symptoms - its r16: While it would give off a whisk every now and then, it never failed with the psu running for 20 minutes - and where the left rail would drop a few mv, and I'd crank it back up... where the led was dying. All making more sense. I was almost convinced the wisps were cat hair or some stray saw dust (hey, it happens - at least it wasn't stray aluminum shavings). Well, except for what the root cause might be? And, an obligatory money shot: |
Originally Posted by runeight /img/forum/go_quote.gif Measure R12. Should be near 150V. Higher wattage is not needed. If everything is working properly 1/8W is 10X more than required. |
