Nebula769
The gain on the BHA-1 is kinda insane. I have my knob at 8-9 at loud listening volume low gain.
No kidding. You can get it changed. Contact Bryston. It's just moving smd resistors around.The gain on the BHA-1 is kinda insane. I have my knob at 8-9 at loud listening volume low gain.
I would but I don’t think I can live without my bha-1 for that long. I heard m-patch passive preamp can help with this thoughNo kidding. You can get it changed. Contact Bryston. It's just moving smd resistors around.
You can just ask Bryston for which resistor position needs to be swapped, and ask somebody to do it for you. It's not difficult.I would but I don’t think I can live without my bha-1 for that long. I heard m-patch passive preamp can help with this though
Did you ever pair the RME with the BHA-1?Anyone have experience with the RME ADI-2 FS and the BHA-1 combo?
I am looking at the Chord Qutest or the RME as a step up from the below DAC‘s also current phones listed any advice opinions welcome.
I have had the BHA-1 for over a year using a topping D70 , dragonfly red, ifi idsd micro bl , bluesound node 2i with HD820, LCD 2 fazer, HD6xx, Focal Elex, Hifiman HE400i
Hi HixsDid you ever pair the RME with the BHA-1?
I agree. The Rag 1, BHA-1, and v281 didn't do as well as the BHCs with the HD-600.I think all the 300 ohm Sennheisers are happier with a good OTL amp. There are certainly at least a handful of top solid state choices also.
Best if you can get used to that logarithmic scale. You’re not getting anywhere near maximum power so it’s not like you’re coming up short. I’ve driven the Susvara to high quality moderate volume, and the critical last boost in volume comes right near the end of the dial… But the amp still has power to spare. It’s built that way.I would but I don’t think I can live without my bha-1 for that long. I heard m-patch passive preamp can help with this though
It’s an extremely high quality, accurate, well designed amp by a company trusted by countless recording studios, the high-end and mobile kind. It’s also famously neutral, and it doesn’t give a hoot what style of music the electricity is carrying. The only way it wouldn’t be good for Rhythmic pop, rock, and electronic would be if it were slow, or flabby in the bass, or had some weird frequency or phase anomalies. Being the kind of no compromise designer and manufacturer Bryston is, plus the fact that it comfortably remains accurate throughout its full power range, this is an amp that is going to give you first class performance driving anything it is powerful enough to drive, which is most headphones… It was a fantastic match with the abyss 1266, which is very power-hungry, a headphone with deep and impactful, fast bass.is the BHA-1 good for pop/electronic/rock music?
The Bryston like all amps just amplifies the input signal, noise free without distortion to an appropriate level to drive ones headphones, the genres is irrelevant. The headphones themselves are what may determine what you are after.is the BHA-1 good for pop/electronic/rock music?
Ditto. : )It’s also famously neutral, and it doesn’t give a hoot what style of music the electricity is carrying.
In a perfect world. Senn HD-600 sounds much different on an OTL (BHC), than on a Rag 1 SE, Rag 1 XLR, BHA-1, and those 3 SS amps sound different from each other.The Bryston like all amps just amplifies the input signal, noise free without distortion to an appropriate level to drive ones headphones, the genres is irrelevant. The headphones themselves are what may determine what you are after.
