Or perhaps I should get a A90+D90.
Experiences with Bryston BHA-1 headamp?
- Thread starter Nicholas Seltzer
gimmeheadroom
andCan you link me that test, or tell me what is the tier up from Bryston? Thanks!
My biggest focus is sound, looks and the fact that I can use it with my turntable. Bryston seems to have a good phono preamp that I could use with my Cadenza black and it could match the look of the BHA-1.
Ok, this is totally off the rails now.Or perhaps I should get a A90+D90.
Sound Eq
- Nov 9, 2013
the other day, I auditioned the bha-1 with my hifiman he1000v1, and i tired an r2r dac and another dac, and so surprised how we needed almost go full volume on BHA-1 on high gain, and the volume form bout 50% till bout 80% was doing nothing in volume. I am not sure if that is some others have experienced, also even with my EC Design R2R dac the sound was cold and analytical and just off
I do not know what could the reason why the BHA-1 had this bad impression on me, although I could have gotten it for a good deal. But it was simply awful. I tried it then with focal stellia and it did have enough volume, but the amp sound simply is not my cup of tea
Maybe we were doing something wrong, I could go back and try again, but wanted to check here again before I do, if there is something to look at when testing again, I also aim to see if it can power LCD4 but I am doubtful as it barely had juice to power he1000v1
makan
- Feb 16, 2015
The attenuators is designed like that. From about 10 to 2 o’clock, there is very little change in volume. I find my BHA-1 outputs more volume than it is rated.the other day, I auditioned the bha-1 with my hifiman he1000v1, and i tired an r2r dac and another dac, and so surprised how we needed almost go full volume on BHA-1 on high gain, and the volume form bout 50% till bout 80% was doing nothing in volume. I am not sure if that is some others have experienced, also even with my EC Design R2R dac the sound was cold and analytical and just off
ThanatosVI
I know someone here on head-fi Who absolutely loved his bha-1 LCD-4 Combo.the other day, I auditioned the bha-1 with my hifiman he1000v1, and i tired an r2r dac and another dac, and so surprised how we needed almost go full volume on BHA-1 on high gain, and the volume form bout 50% till bout 80% was doing nothing in volume. I am not sure if that is some others have experienced, also even with my EC Design R2R dac the sound was cold and analytical and just off
So from what I've heard the Bryston has no problems driving them
I've been using the BHA-1 for a few months now and I'm finding it does a nice job, on HD650, HD800s, LCD-3, Dave Clark phones, even the HE-6 V1. I've also noticed a big increase in dynamics when the bal xlr's are used in lieu of the 1/4 jack. So I contacted Bryston , Their answer. :
The big advantage of using the balanced outputs on the BHA1 is the doubling in output voltage, because, as mentioned in the forum, you have two class A amplifiers driving the output rather than one. This doubling in voltage actually results in a 4 times increase in power, since power is proportional to voltage squared.
This applies to both the 3-pin XLR connectors and the 4-pin XLR connector.
The question of how much advantage there is to having 4 times the power is difficult to answer. For most headphones, the power isn't strictly necessary, but can improve the dynamic response of the amp. For some more difficult-to-drive headphones, the extra power would be required to drive the headphones to their maximum useful level.
The 'phones you mention below probably fit mostly into the first category from a specification standpoint, but the Audeze's reportedly benefit from extra power, and my experience with the HD800's is that the difference between single ended and balanced operation is significant, specs notwithstanding.
Thanks,
Mike ""
Thanks,
Mike ""
Thanks,
Mike ""
How would you characterize the sound?
Anyone have experience with the RME ADI-2 FS and the BHA-1 combo?
I am looking at the Chord Qutest or the RME as a step up from the below DAC‘s also current phones listed any advice opinions welcome.
I have had the BHA-1 for over a year using a topping D70 , dragonfly red, ifi idsd micro bl , bluesound node 2i with HD820, LCD 2 fazer, HD6xx, Focal Elex, Hifiman HE400i
Clean, Neutral, fast, bass is tight . Some awesome used deals out there under $1400How would you characterize the sound?
tamahome77
The bha-1 pairs very well with hd800s but not with the he1000v1 - just couldn't drive it with authority. The jot 2 does a much better and more capable job of driving the he1000v1.
teknorob23
Member of the Trade: Network Acoustics
I've had my BHA-1 for just over a week and i'm very impressed. Depth in staging in is rarity and a real grail for me in amplification, and coming from the V281 which was lovely but had pancake flat stage, the Bryston has been a bit of a revelation on this front. I put this down to the levels of transparency it delivers, able to resolve the the nuances in the staging and pull photograph into 3d moving images.. if that makes any sense. Obviously the levels depth revealed are dependent on quality of the recordings/ mastering of the material which is being fed through the amp. Anyway i havent heard anything like this in an SS amp, since i sold my Feliks Audio Euforia AE tube amp and the BHA1 adds a greater dose of detail and clarity in the process.
The apparent synergy with the rest of my system is also a big contributory factor as i have a bit of warmth in the my DAC and HPs fed by one the most natural streamers i've heard:
Bricasti M5 Streamer > Denafrips Venus 2 DAC > BHA-1 > Focal Stellia
The Bryston has been on my radar for a while, always enjoyed their hi-fi products, but i was expecting it to be stepping stone to another amp, but based on my experience so far i'm not sure i'll need to do much stepping for a while.
I'll try and share something a bit more comprehensive when i've good a few more weeks of listening under my belt
By all means don't forget to try out the XLR connections. I found a big improvement in dynamics .
teknorob23
Apologies i didnt give very precise info on my set up. I am using both the balanced inputs and headphone output. I havent actually tried it unbalanced.
OK, cool ! could tell the difference between the XLR's and the regular jack ? I Know I could, when using HD800's and HD650's.
mortcola
- Dec 19, 2013
Hi Nicholas - So, your post is four years old. I'm wondering - what did you end up doing re Mjolnir w/SS tubes, and asking about the BHA-1. I got a chance to upgrade - Gumby and Mjolnir2 with LISST and other tubes, now using the Bryston BDA3.14 and BHA-1, as well as a Woo WA5-LE.Currently using a Schiit Mjolnir 2 with solid state tubes and looking to upgrade. Any experience with Bryston BHA-1? what else should I consider in the 1300-1700 price range? I had a Ragnarok briefly that I had to return due some malfunction secondary features, but I enjoyed the sound.
Headphones: LCD-3F
I'm delighted with the Bryston gear. I remember some good big-speaker auditions using Bryston, but had no experience with their stuff for decades. The DAC/Amp combo is head and shoulders better than the SChiit in most respects, using both Grado GS3000e and Empyrean cans. Like a thick curtain has lifted off the music. What was engaging, reasonably resolving, totally enjoyable in the Schiit-based system is now as close to end-game as I can imagine without spending a lot more....and I don't get many opportunities to spend even this much. Transparency, perfect dynamic envelope (groove with delicacy, bass-slam with clear tonality, timbre, speed, and harmonics); extremely natural.
And, the SS Bryston amp is a neat compliment to the 300B Woo amp - it doesn't sacrifice much in the tonality department - there's loads of natural soul coming through the music despite the "clinical" and "boring" knee-jerk adjectives I've hard applied to Bryston. Great frequency extension, but even with the Grado phones, which have a lovely richness, retain their extraordinary presence but also their intolerance of any high-frequency assertiveness in the signal, the Bryston drives them without a hint of glare.
The Empyreans? Strange, I'm a presence-and-sparkly-treble guy, and I was skeptical auctioning the Empyreans, given that one dealer called them "pleasant but not reference", and some forum contributors called them "dull". I've found them to be great chameleons. Other than being a welcome, make yourself at home kind of headphone, they really deliver the character of the music. One set of adjectives simply doesn't apply at all when listening to a very different recording, as if a different headphone entirely. And the Bryston seems to pair with them beautifully. If at all possible, I want to hear them with different TOTL cans.
The Woo WA5-LE is quite a beast. Great transparency, the 300B legendary midrange is there, but never at the expense of clarity. I'd like to think I'm saving for Holo gear, and maybe a Susvara or Abyss, but honestly, I have no quibbles with anything here, no "if only" or good, but...". I shouldn't, at this level, but what audiophile is ever satisfied?
