PeacockObscura
Just got the ie 600 any tip recommended for boosting the bass a bit? They are sounding just a touch lacking in comparison to my acoustune 1670ss
That great I've just received some of them through the post 5mins agoFinal Audio Type Es
Oh yes that did it! Wow those included tips don't do the ie 600 any favoursFinal Audio Type Es
The stock tips are pretty bad. I prefer the IE Pro tips to the Final Audio type E ones though. Bass is equally present in both imoOh yes that did it! Wow those included tips don't do the ie 600 any favours
Try the azla sednaearfit standard black when you can I use them on my ie300 & ie600 also on the dunu zen pro.Oh yes that did it! Wow those included tips don't do the ie 600 any favours
Mojo2PolyJust got the ie 600 any tip recommended for boosting the bass a bit? They are sounding just a touch lacking in comparison to my acoustune 1670ss
how is the EQ setting? It looks wayyyy to mid focused for me. especially with that drop in bass
I don't get it... Why in god's name would you buy a 600$$ iem, and then tune it to a Harman Curve?!?!how is the EQ setting? It looks wayyyy to mid focused for me. especially with that drop in bass
You are right it's not mid focused. I misread the numbers. It's got crazy gain in the 3-6k area which the 600 does not need imo but I assume is to offset the dip at 10k. Either way I 100% agree that it's silly to go through such lengths to EQ the 600 to harmanI don't get it... Why in god's name would you buy a 600$$ iem, and then tune it to a Harman Curve?!?!
Just get a Kato, or a Fiio FD5 or something.... They will practically always be better because of lower THD, as they are not EQ'ed...
Ps. Would not call the Harman target mid focused...
