Yeah a bit microphonic when walking around but that doesn't bother me, lengthwise it's perfect and sits nice and straightYep, it's a love and hate relationship with the stock cable. I myself found it tolerable for the 1st few days. But been using it daily since purchasing it and found it very microphonic and stiff to my liking, hence I moved on from the stock cable.
Exceptional in Every Detail: Say Hello to the IE 600
- Thread starter Sennheiser
Find an authorised retailer and they will have it within a week.Are the IE 600 realesed all over the world now? In my local hifishop ( hifiklubben.no ) it says that they expect it to arrive 23 may.I live in norway.
InfectiousAudio
Got my IE600 last week..and I'm blown away! These are my first IEMs and the tuning is just perfect. Incredible imaging and dynamic range.Ordered from Amazon.co.jp to Canada, ended up being slightly cheaper than local dealers & arrived sooner!
Paired with the Qudelix 5K, which luckily was in stock when I happened to visit Qudelix's site, it's the perfect combination. Nothing but good things to say about how it sounds and the included features, working perfectly with the IE600 in balanced or unbalanced setups! The parametric EQ is something I'm especially enjoying playing with. Seamless pairing with Bluetooth devices makes for a friction-free experience on iOS, macOS, PC, Android, etc.
frix
- May 7, 2012
No sennheiser @high-end in munich. Disappointing guys, hoped to have a listen to the IE600.
M3NTAL
- Oct 8, 2006
Which 2.5mm balanced cable are you using for the 5K -> IE 600? I really don't want to create an account on AE to order the MMCX MMCX adapters.Got my IE600 last week..and I'm blown away! These are my first IEMs and the tuning is just perfect. Incredible imaging and dynamic range.Ordered from Amazon.co.jp to Canada, ended up being slightly cheaper than local dealers & arrived sooner!
InfectiousAudio
Using a 4.4mm to 2.5mm adapter, maybe not the best solution but it does seem to be workingWhich 2.5mm balanced cable are you using for the 5K -> IE 600? I really don't want to create an account on AE to order the MMCX MMCX adapters.
C_Lindbergh
Cmon Sennheiser, make a true wireless adapter for your new In-ear series! The technology for stable low-latency CD-quality BT sound is finally here
https://www.qualcomm.com/products/application/audio/qcc30xx-series/qcc3071
Too far from their Swiss homebase, I guess.
Lightspeed12
Still waiting on my qudelix 5k its been shipped about a week ago now & I have had the ie600 for about 2 weeks.Got my IE600 last week..and I'm blown away! These are my first IEMs and the tuning is just perfect. Incredible imaging and dynamic range.Ordered from Amazon.co.jp to Canada, ended up being slightly cheaper than local dealers & arrived sooner!
Wouldn't mind getting a short cable made up for on the go, instead of having excess cable hanging off me. Lol
Welcome to the addicting world of IEM and especially the #IE600Club! Would love to know what tracks you're using to put them through their pacesGot my IE600 last week..and I'm blown away! These are my first IEMs and the tuning is just perfect. Incredible imaging and dynamic range.Ordered from Amazon.co.jp to Canada, ended up being slightly cheaper than local dealers & arrived sooner!
Stay updated on Sennheiser at their sponsor profile on Head-Fi.
scarfacegt
- Nov 4, 2010
How is the isolation on the ie600? And have anyone tried spinfits with it? I have spinfits on my shures,and they are easy to take in/out and are comfortable.
Lightspeed12
Isolation is good with the right fitting ear tips & I have tried spinfit cp100s & they are good so are sony hybrid tips but my favourite so far is the azla sedna earfit standard ones or the lights.How is the isolation on the ie600? And have anyone tried spinfits with it? I have spinfits on my shures,and they are easy to take in/out and are comfortable.
I'm currently comparing specs on all tips as we speak. Any place where I can find bundled info? I'm particularly interested in nozzle width (at the tip not stem) and lenght.Isolation is good with the right fitting ear tips & I have tried spinfit cp100s & they are good so are sony hybrid tips but my favourite so far is the azla sedna earfit standard ones or the lights.
Lightspeed12
The azla sedna earfit have a nozzle width off 5.4mm which is why I like the sound they produce. Pretty close to the sennheiser ones that come with the IE600 for looks without the grill & made off better silicone.I'm currently comparing specs on all tips as we speak. Any place where I can find bundled info? I'm particularly interested in nozzle width (at the tip not stem) and lenght.
P Xavier s s ssc
Thank you for that info.The azla sedna earfit have a nozzle width off 5.4mm which is why I like the sound they produce. Pretty close to the sennheiser ones that come with the IE600 for looks without the grill & made off better silicone.
