Which adapters are you using?
Exceptional in Every Detail: Say Hello to the IE 600
- Thread starter Sennheiser
Takeda`1537
Takeda`1537
both types work very well (compared to others that I have bought and binned) .. they only have different wear
PW Audio cables work well with the IE series of IEMs. (I bought their Moloch cable for my IE600.) They have a secure fit that doesn’t rotate easily. I had occasional problems with one side cutting out with the stock cable but have had zero problems since getting the Moloch.
Takeda`1537
with the adapters, cables can rotate without damaging the sockets
Does the adapter itself rotate around the earbud's connection?
Takeda`1537
not the first one (the smaller of the two). This one is pretty firm.Does the adapter itself rotate around the earbud's connection?
the second one (the bent one) does but, so far (for the last 6 months that I had that one on) connection is really good.
lowrider007
I've been doing a lot of research into what could be a potential upgrade from the IE-600 and it doesn't seem an easy task, everything under 1k seems to be a side grade/tuning preference rather than a flat out upgrade, I don't have much experience over the kilobuck threshold, what IEM(s) could you comfortably say are a big upgrade over the IE-600 or has this IEM really hitting the upper hemisphere in terms of performance?
RIGATIO
Technically it will be a difficult task. The ie600 are very capable when it comes to detail, separation and timbre. They compete with the ie900 so the ie600 are still as good as most iems under 1500 bucks.I've been doing a lot of research into what could be a potential upgrade from the IE-600 and it doesn't seem an easy task, everything under 1k seems to be a side grade/tuning preference rather than a flat out upgrade, I don't have much experience over the kilobuck threshold, what IEM(s) could you comfortably say are a big upgrade over the IE-600 or has this IEM really hitting the upper hemisphere in terms of performance?
When it comes to the tuning, you can find more neutrally tuned iems under 200 bucks.
Symphonium EuropaI've been doing a lot of research into what could be a potential upgrade from the IE-600 and it doesn't seem an easy task, everything under 1k seems to be a side grade/tuning preference rather than a flat out upgrade, I don't have much experience over the kilobuck threshold, what IEM(s) could you comfortably say are a big upgrade over the IE-600 or has this IEM really hitting the upper hemisphere in terms of performance?
Takeda`1537
These days you can get pretty good deals on most IEMs on classified ... UM Maven, Symphonium Crimson and Trio might be good options to consider...I've been doing a lot of research into what could be a potential upgrade from the IE-600 and it doesn't seem an easy task, everything under 1k seems to be a side grade/tuning preference rather than a flat out upgrade, I don't have much experience over the kilobuck threshold, what IEM(s) could you comfortably say are a big upgrade over the IE-600 or has this IEM really hitting the upper hemisphere in terms of performance?
gto88
- Dec 11, 2014
Just received IE600 today, did a short listen, it is really good, detailed, separation, sweet bass.
Should have bought it earlier, but I got it on BF sale, couldn’t be happier.
Waddiewadkins
Yesterday sent email to support finally within warranty to tell em I want to send my 600s that both now cut out (with different cables). Hope it goes smoothly!
Takeda`1537
Fingers crossed ... please let up know how it goes and if Sennheiser is good good with support too...Yesterday sent email to support finally within warranty to tell em I want to send my 600s that both now cut out (with different cables). Hope it goes smoothly!
Waddiewadkins
I thought the cutting out thing that has been talking about,,that : "nah it won't happen to me, thats you poor people".. But Lo.. it happened to me. Started out small maybe in one side, took 5 months to get to now,, I can't wear a hood over them without them cutting in and out with every step. Not good for winter it turns out.
Total: 10 (members: 0, guests: 10)
