mordy
- Aug 8, 2010
Well, I am very happy to announce Wieslaw is going to begin working on this amp for me at a very reasonable price!
This type of capability built into an amp is going to be amazing IMHO. Essentially, seems he's just gonna take the H5M and build these modifications/capabilities into that, which is exactly what I was looking for actually!
Will end up having two voltage regulators with digital displays built-in, which I will be able to adjust within a 2V-30V range, which suits my needs just perfectly. Also, discussed the need to have it be able to run dual Type 24 inputs + 6336/6528 output, which is quite a bit of current to handle there, which would be the very high end of current from any combo of input/output tubes I will be running.
I really can't wait to be able to get rid of these ugly adapters with wires running to my external PS, super eyesore, but I am glad I did this, otherwise there would be many tubes I would have never tried - so in the end, it was all worth it.
Thanks
Agree with the point about aesthetics- after a while you tire of all the ugly wires and connections.But it is a very good learning experience and allows you to find great sounding inexpensive tubes as well as safely running your amp on much more power than it was designed for.
