I'm checking with him on these tubes now.
Sure why not. I just didn't want to burn a hole in your pocket with NOS tubes for these but you could always try new production tubes first. They are not the same though.
6SL7 aren't that expensive and you can certainly get some. Even the good ones.
Thanks for clearing it with Eric, very nice of you.
And good to know for the back of my head.
Might be a good addition if the gain is quite high to compensate with one of these tubes,who knows.
Have in fact found 2 manufacturers for the Kt and EL34 tubes who have currently made the new production.
I looked for a Gec Kt 66 but it was almost unaffordable.
Nick's amp looks really nice and classy.
Big wow for the true symmetrical XLR connection.
XLR does indeed sound a bit smoother and softer in general I have noticed myself when I connect the Euforia with a cable Xlr to Rca.
However, one must bear in mind that this method can lead to clipping.
Because the voltage output is just under 4 volts instead of 2 volts.
This can be remedied if you don't overdo it with the volume.
The other thing I would like to add is that the Mundorf capacitors take a good 20 hours to arrive, I have read.
Unless Eric has warmed them up beforehand, you should wait at least 20 hours before committing.
I also think that the rest of the component amplifiers typically take a little time to fully get where they need to be.
Usually it is 50-100h burn in.
However, the description of what you have found is amazing for the first few hours and really reassuring for those who have ordered the Ultimate.
The location of the headphone jack is also very well chosen being in the front.
That's something I might have to discuss with Eric if he hasn't started yet.
Whether it would be feasible to do that as well.
I wish Nick a lot of fun with his new toy and praise for his choice.
The equipment is also very lavish and generously chosen and no expense has been spared in fully equipping the UltimatE.
And Eric has done a really great job, it looks really great, and the layout is really nice to look at.
I really like it.
