Eric McChanson Headphone Amp??
May 27, 2023 at 5:43 PM Post #1,321 of 9,894
I'm listening with Susvara and Odyssey on Beck's Morning album. I wonder what I am smoking that I neglect this setup for the last month. All I had are Shuguang KT88-Z Thousand Treasures in there.
May 27, 2023 at 7:11 PM Post #1,323 of 9,894
It's an uphill battle because as soon as I go back to Grado and Ultimate, I am a happy vegemite again. :xf_cool: I get what you are hearing @Leicachamp. I understand now why you got rid of Utopia, Final D8000 and that megabuck Riviera AIC-10 amp when you hear your Grado with Ultimate.
May 27, 2023 at 7:18 PM Post #1,325 of 9,894
Perfect. I don't hear much difference between 6y6g and 6y6ga. I haven't tried 6y6gt but I have tried 6w6gt and it's similar sounding. So you are good to go with that.
What 6y6 tubes is Eric giving you?
May 27, 2023 at 7:56 PM Post #1,329 of 9,894
Eric just told me that he is about to flick on the power switch for Nick's amp. :dt880smile: He's so excited.
I can pick it up tomorrow. Will schedule a meet up with Nick earlier. I'm sure he's dying to get his amp.
May 27, 2023 at 8:08 PM Post #1,330 of 9,894
In the words of Eric...
switched ON, All look good now. measure the voltage and current fine. and sound from speaker sings well, Insert the Grado to check.. Wow, there is no different if the Grado is inserted or NOT, the same quietness.... I am OK with the amp
:thumbsup: :wink::beerchug:
May 27, 2023 at 8:45 PM Post #1,331 of 9,894
I don't think I asked him exactly what they were except that he mentioned they were 6y6G.
They arrived the day before yesterday and I'll be listening to them at Euforia this weekend.They are new.
The Brimar from Langerex also arrived, as did the 6bw4 Dumont.
I've already got everything I ordered together.
May 27, 2023 at 8:51 PM Post #1,332 of 9,894
Those Raytheon 6y6g black glass looks exactly like the GE 6y6g black glass. These are wonderful sounding tubes.
I might be trying out other rectifiers soon. Eric suggest these other rectifiers - 6V4, EZ80, EZ81.
May 27, 2023 at 9:07 PM Post #1,333 of 9,894
Eric said
The amp is wired OK to use 6V4, EZ80, EZ81... Note these tubes are NOT pin compatible with the provided 6BW4, but the amp is wired that the amp can use all these tubes.
No adapter is needed. as I hard wire the amp to use these : 6bW4, 6V4, EZ80, EZ81 ( EZ81 is a bigger tube, and the filament current is a bit higher than the others, the UltimatE can handle)
May 27, 2023 at 9:17 PM Post #1,334 of 9,894
The dog doesn't care if it's windmill, solar or battery powered. He's more interested in a steak !
… if the tube has ‘filamignons’ in it, he’s all ears teeth 🤣.
May 27, 2023 at 9:30 PM Post #1,335 of 9,894
If you're ever in doubt about using 6y6, 6w6, 6f6, 6v6, this is what Eric has to say...
I test UltimatE with 6W6 and 6F6... they can work in UltimatE all good... As for working voltages ranges ( current needed related ) from low voltage to high the range is 6Y6, 6W6, 6F6, and 6V6.
So the 6W6 and 6F6 are between 6Y6 and 6V6.... and so many 6?6 make us confusing but they all work OK in UltimatE.
