Deleeh
Bought another Ez80 from Bel, which is actually Mullard.Eric said
The amp is wired OK to use 6V4, EZ80, EZ81... Note these tubes are NOT pin compatible with the provided 6BW4, but the amp is wired that the amp can use all these tubes.
No adapter is needed. as I hard wire the amp to use these : 6bW4, 6V4, EZ80, EZ81 ( EZ81 is a bigger tube, and the filament current is a bit higher than the others, the UltimatE can handle)
With Eric's and the Dumont, there are 3 rectifiers to start with.
I think that's enough.
I can change the tube normally, did I understand that correctly if 6bw4 was in there before, just put in Ez80 and I'm done?
The translator sometimes translates really strange lately.
I haven't even looked for 6v4 yet.
The Raytheon were lucky, a friend had found them and linked them to me, so I really couldn't say no.
I'll let you surprise me, I still have a few Sylvania in mind that are also supposed to be good.
With all your 12at7 recommendations where I have mostly found some and one or the other myself, with the 6sn7 what I have here and 3 pairs of 6v6 I am really not badly positioned for the UltimatE for the beginning.
The only things missing are Kt66/88,6SL7,EL34.
I wonder if 6BX7, 6BL7 might still make sense.
