Eric McChanson Headphone Amp??
Jan 29, 2024 at 6:15 PM Post #8,596 of 9,894
Lucky that i am retired over 7 years ago and enjoy my music. I can sleep anytime, will roll both tubes and amps when i receive the S UltimatE.:L3000::darthsmile:
Always impressed by your stable, Van!👍😎
Jan 29, 2024 at 6:41 PM Post #8,599 of 9,894
Yes, i have a few ZMFs
Jan 29, 2024 at 6:42 PM Post #8,600 of 9,894
How does the mcchanson amp compare to the sonnett?
Jan 29, 2024 at 6:51 PM Post #8,601 of 9,894
Eric is building my S UltimatE now and i hope to receive it in early of March. Of the 4 amps i have now, Woo WA22 ( 2nd Gen), Ultrasonic Studios Oblivion, LTA MZ3 and DNA Sonett 2. The DNA has the best vocals, i love vocals and mids.
Jan 29, 2024 at 7:39 PM Post #8,602 of 9,894
For the nerds amongst you, this is from Eric….
In all McChanson ( including UltimatE ) amps, the power tube socket has pin 1 tied to pin 8 ( pin 8 is the cathode ) for the 6L6GC family power tubes, As for those Glass GT or G tubes, pin 1 is NOT used, so it has no affect. if the power tube is metal, then the metal is then connected to the cathode and there are two effects :
(a) As continuous as isolation as before - no problem.
(b) Bring the metal tube onto the cathode with the cathode voltage ( if the power tubes are auto-bias, as in UltimatE, the effect is minimal on fixed bias as the standard integrated amps. , as in this case the cathode voltage is very low.)
The effect of (b) is that the metal tube carries a cathode positive voltage, but as it is about and less than 20V, no harm to touch. but one precaution that needs to be noted is that do not connect a wire from the metal tube to the chassis which may make the cathode voltage to zero that is no good... but who else wants to do that, mostly it is accidental.
One may ask can we remove the connection between pin 1 and pin 8? Yes we can, but when we use tubes like EL34, we may need an adapter EL34 to 6L6 socket adapter, also when we use metal tubes we lose the shielding effect.
Jan 30, 2024 at 12:15 AM Post #8,603 of 9,894
Added below the table. Good to document and preserve those pearls of wisdom from Eric! :pray:
Jan 30, 2024 at 12:20 AM Post #8,604 of 9,894
Jan 30, 2024 at 12:40 AM Post #8,605 of 9,894
Jan 30, 2024 at 3:28 AM Post #8,607 of 9,894
Very nice, you have done everything right, I would love to spend a few hours with your toys 🤩
It will be exciting to see what place UltimatE will take, maybe something will be displaced 🧐
I recommend a backup for the EL39, I wouldn't sleep easy with just one pair. 6EM7s are not yet in evidence...
Jan 30, 2024 at 4:01 PM Post #8,608 of 9,894
I retired 7 weeks ago and now spend my time supervising my wife to make sure she does things to my satisfaction.
(and if you believe that last part, I'm still selling bridges as a part-time gig :smile:)
