stevenkelby
- Jul 17, 2006
I'm getting my SPL meter back from a mate tonight so I'll at least run some tones and sweeps to see where I'm at now. I do plan on room treatment to try and fix big errors but can see that only an EQ can do the fine tuning. 2 identical systems in different rooms will sound different. EQ must be the best way to avoid that as much as possible, once room treatment has been done.
i'll start with traps in the corners and panels behind the speakers. My room is not ideal which is why i'm wanting to do something in th first place, and while I'm doing something to fix the FR, why not do it as well as possible?
My old room, I never considered it as teh sound was close to flawless, the room was almost perfect.
I can see how people would make things worse with an EQ but I'll soon figure it out, I know where to start and know what I'm doing in a car, same principles apply I assume.
Originally Posted by jp11801 /img/forum/go_quote.gif generally speaking I am against eqs for no other reason than most people tend to use them incorrectly. Unless you know what you are doing an eq can be a pandoras box. I know Steve will tell you different but the learning curve can be steep. One thing to think about is room treatments they are relatively easy to set up. |
