Originally Posted by sejarzo /img/forum/go_quote.gif
Thanks for all that info, I'm happy to pay $40 to get what I need, if I need it. I'll look into it.
The problem is my PC is in another room, the case weighs over 60 pounds (30KG) and it's a pretty permanent install. I don't have a laptop but have been thinking maybe I need one...
If I really need to (and it seems I do) I will relocate the PC to the loungeroom for the equalizing but I'll get well organized first.
This is the SPL meter I have here:
Jaycar Electronics
It has a 3.5mm jack on the side labeled:
DC.AC OUTPUT
I plugged in a mini - RCA cable to my stereo and it sounded just like a microphone but only in the left channel, there was no sound through the rt channel. I guess I need a mono 3.5mm plug, which I will get and make a cable. Actually I think I have a couple mono 3.5mm here which I was sent by accident, I'll have a look.
I guess I need a cable going from the SPL meter 3.5mm mono to a single RCA plug, and will measure the channels separately.
The sound card I have is the Chaintech AV-710, which is in the PC but hasn't been used for a long time. I use the Pico and don't ever use inputs to the PC.
I guess a 3.5mm mono to 3.5mm mono cable would be needed.
Bigshot, I'll play around with grounding when I get a chance but my system is normally "silent". I think it's just the 231 introducing noise, I will definitely try playing with grounding though.
Won't be touching it tonight sadly, tons of work to do.
Originally Posted by stewart572 /img/forum/go_quote.gif
Steven
Copland makes a device that does that. I think Audio Connection in Sydney had one 2nd hand
Stewart
Thanks Stewart
I couldn't find an EQ there but I found the Copland DRC-205 elsewhere, but all their gear looks very expensive and has more features than I need. I only need 2 channels etc.
I'm really thinking about the Rane DEQ60, if it sounds good. That's the kind of thing I need I think. It also has the option of 2 curves so I can have one for CD and one for vinyl, to "fix" the freq. response of the TT if needed.
Some great help so far, thanks all.
