EQ = sound quality?
Oct 11, 2012 at 12:21 AM Post #92 of 102
so what about using better amp ? or even DAC ?
How do we determine that if using DAC / amp like Fiio E11 can actually boost sound quality ?
Oct 11, 2012 at 12:25 AM Post #93 of 102
That's a whole other set of discussions. Personally, I would rather have amps and dacs that measure neutral and implement a separate eq somewhere in the chain (digital or other), rather than using the dac/amp as a "hardware eq." That gives me more flexibility with a wider range of headphones and usages.
Oct 11, 2012 at 1:17 AM Post #94 of 102
Thanks for the reply Liam, yes I'm using Windows Media player Eq and also DENON iPhone apps player (10 band graphical EQ).
what does that mean by "measure neutral" ? I thought that by using EQ and Amp the sound is no longer neutral.
Oct 11, 2012 at 2:03 AM Post #95 of 102
By measure neutral, I mean that the dac and amp do not color the sound. No bass boost, no audible roll-off, etc. A wire with gain (and if desired, maybe some tubey second order distortion) - but no permanent/uncontrolled changes to frequency response. That's the EQ's job.
Oct 11, 2012 at 7:09 AM Post #97 of 102
Yes. And this is how an amp that's normally powerful enough to drive a pair of not so sensitive headphones can easily get maxed out. With my subtractive EQ and Replaygain on, I measured a volume reduction of a full 12 dB on my system!
Yup, before I got a Fiio E17 with 12dB of gain I had to cheat by letting the EQ go above the 0dB line and use a limiter down the chain for insensitive headphones.
Oct 11, 2012 at 7:43 AM Post #98 of 102
I like Electri-Q though, it can do narrower bandwidth cuts than EasyQ and I'm just used to it and have made lots and lots of presets for it XD
What purpose does oversampling serve, does it somehow make the non eco mode better?  I'm inclined to think that eco mode is better right now but all my presets were made in non eco mode and switching modes changes the filter FR according to the graph the program draws :/
I think you will love Engineer's Filter Joe Bloggs.
Anyways, I did not post as promised on the advanced eq thread as promised but I would like to say the concept of it and doing it has really given new life to my headphones. To prevent clipping I usually set global gain down by 3db. Never mind reduction in non linear performance, the gains in terms of FR and my experience that I got makes it totally worth it!
As for replaygain, I decided to have it of and move the volume knobs as I need it.
Oct 11, 2012 at 10:03 AM Post #99 of 102
Yea I want to set my Global Gain dwn in my presets as well. I'm so used to FooBars auto zero function, although I know some one here just told me how to do it so I'll have to back tracka little!
Oct 11, 2012 at 1:33 PM Post #100 of 102
add a Gain control point / band / whatever you call it (click on the graph to create a point, right click on it and select Basic->Gain only) to move the entire graph down below the 0dB line.
