ProtegeManiac
Thanks for the response, it really helps me out since I’m still new to the whole game.
You try the lyr 2 or the wa6? Any opinion on what the difference are beside hybrid and transistor coupled.
Does the lyr have more closer to a solid state kind of a sound or does it still sound like tubes?
Lyr is warmer than the Asgard but still not totally tubey if you're looking to EQ the sound rather than just put clean power into the headphones. WA6 is slightly more rounded and has more precise imaging but if you're thinking of using a warmifying boombasticator instead of an actual amplifier not even the WA6 (and don't even think about the cleaner sounding WA22) will be a good option other than if you plan on rolling tubes to a set that really warmifies for a truly boombastic sound so syrupy you better keep the amp away from ants.
