leeperry
Galvanically isolated his brain
- Apr 23, 2004
you can open two foobar instances, sync them and run them in loop.
Originally Posted by Graphicism /img/forum/go_quote.gif Simply plug in the headphone to the DAC1, listen for say 30 seconds, unplug and plug into the EMU and listen for another 30 seconds. If you can take it one step further, have someone blindfold you and have them do the changes for you. |
Originally Posted by Shadorne /img/forum/go_quote.gif I don't need to compare headphones to know that the HPA2 inside the DAC1 is going to absolutely kill the EMU when driving the majority of headphones. Of course the rather low damping factor of around 3 of the EMU (with such high output impedance) may give the impression of better heavier bass (warm tubey sound ?) but that would be a significant alteration of the bass response which may help certain headphones only Not trying to pick a fight here - just sticking to stated specifications. |
Originally Posted by regal /img/forum/go_quote.gif being better than a Benchmark DAC1 is really not saying much at all. The only thing the DAC1 ever had going for it was the balanced output. If you don't need that there are many many DAC's with smoother fuller sound for much less $'s. |
Originally Posted by infinitesymphony /img/forum/go_quote.gif Still, I've read through that test, and my conclusion was that the results were only valid for the group of people being tested. A different group of ears may have arrived at a different result. This is why many people question the usefulness of DBTs, as they can only prove what sounds subjectively better to a test group or individual. In my opinion, the usefulness of DBTs is discovering whether or not people can hear a difference at all between equipment, not necessarily determining that a piece of equipment inherently sounds better. And even in that case (for example, comparing MP3 and lossless formats), the result is only applicable to the test group or individual. |
Originally Posted by magma79 /img/forum/go_quote.gif i have a question which may see duhh to some hoping for confirmation if i will be using an external amp would their be any difference in the DAC of an emu 404 usb and an emu 404 PCI? i ask since there is almost an 85$ price difference between the 2 versions i plan to use PC as source and an external int amplifier to power studio monitors would the PCI version make more sense /? |
Originally Posted by donunus /img/forum/go_quote.gif uhm, anyone able to answer my question whether the 0404 now works with vista? |
Originally Posted by Shadorne /img/forum/go_quote.gif I have both. I use the EMU 0404 USB occasionally to generate test tones/sweeps and record and power a measurement microphone - it is an excellent product good value and does what it does well. However, I use the Benchmark DAC1 daily to listen to music via ATC 100's. Enough said. |
Originally Posted by MarkMDR /img/forum/go_quote.gif I don't want to hijack the thread, but wonder if y'all could give me some pointers of other options between the $199 EMU and the $1K+ Benchmark? I'm driving ATC SCM-20SLA active monitors. I was running an RME Digi96 PCI but just upgraded to vista and can only get it to work with certain apps - they are no longer supporting the card, so only ASIO will work. That's fine for things like mediamonkey, but not Netflix on demand, Pandora, etc. I just don't want the hassle of something else for low res apps, switching back and forth etc. I certainly don't need to spend more if the EMU is 95+% for 20% cost. Just need clean 2 channel (balanced would be preferred). I swapped in my little HeadRoom BitHead just to see how close it was - not close by a mile, the RME was dramatically better even though it was internal. I must say I'm not sold on the internal/external thing either, yeah there is a lot of noise but it's all in the MHZ/GHZ range, and those are the cards that they record the stuff with in the first place, so it can't be soo bad. I do respect Doug's ears, one of his techs taught me about horn speakers 15 years ago and Doug helped me tune up one of the prototypes. Killer system he has in his lab. But he also taught me to be a skeptic of the "wine and cheese" audiophile products. As you pointed out, lots of variances are caused by impedance problems. Thanks!! Mark |
