- Mar 12, 2009
How about that cable? I wonder if it’s an effect audio cable? The prototype had a PW Audio cable
Its not bad. I thought it might be a bit meh . But its fairly soft. Similar to Indigo probs. It looks like PWaudio but i never asked.How about that cable? I wonder if it’s an effect audio cable? The prototype had a PW Audio cable
What do you guys think of faceplate? You like it? I know my pic is horrible but it gives an idea
Looks unfinished to me and not at all premium for what it’s going to cost !What do you guys think of faceplate? You like it? I know my pic is horrible but it gives an idea
I somewhat agree but the seam on the faceplate makes me thing that there is more going on here than what meets the eye…. At least I hope. Far too subdued for my tastes.Looks unfinished to me and not at all premium for what it’s going to cost !
I‘m guessing it’s not final and still missing some polishing.
It is the final unit & not a prototypeLooks unfinished to me and not at all premium for what it’s going to cost !
Can you please weigh the shells?It is surprisingly light for that size. And the shape is just right for me to fit. Size will be an issue for small ears.
But for me, i could probably go for a jog with those. Although i never had fit issue with EE iems.
They do stick out a lot as expected.
Almost none from what i know. Im the 3rd or 4th person to try it i trust. And i probably had most time with it.
EVO will be more of a basshead set as its treble is rolled off. Raven has more air and sound more spread out in all directions and more layered. Spaciality is really impressive.
Raven will be capable of covering more genres. But its by no means bass light.
Well its a bit tricky to go from memory. And i personally dont think there is much difference in EVO vs Odyssey bass in isolation. Evo just lacks air so bass is a bigger highlight. Its been a while since ive heard both so someone who will own both will need to confirm this. If you already did A/B id probably better listen to you than me.. I have not heard the prototype..
From memory i think Odyssey mids are warmer. Raven is not lean in the mids by any means. I found Odyssey a touch too warm for me. But again it probably needs A/B to confirm, or at least fresher memory.
Treble wise. Raven is a touch more energetic and has noticeably more upper treble.
Shouldn’t you be arguing with Tamtrum?I quite like the shell design. But I prefer more understated/sleek over flashy/blingy. This looks more premium to me than Odin or Odyssey My fav designs from EE have been LX, Evo, and now Raven.
But… Jesus Christ that “IEM” is MASSIVE.
… and quite protruding. That is why it is also very important for me to know the weight.But… Jesus Christ that “IEM” is MASSIVE.
And how much do Odyssey and Evo weigh?going by the driver count and assuming the outer cover comparable to EVO/ Odyssey, it should weigh around 2 x Odyssey - 1 x EVO
