Evo ordered.
Let the countdown begin…
Sharing thoughts...
Feels like my LX (and the world) is conspiring for me to get the EVO.
First... noticed some fainting on the LX Left side.
Second... noticed a "not so apparent" crack line crossing almost the whole length of the LX Right side.
Yesterday... sold my beloved and underrated SD5.
My wallet is already hiding from me...
Random tidbit, Charles actually found out he has another customer with the exact full name as I do. Turns out he sent one my of invoices to the wrong one.
Pretty funny if I buy an Evo and the other guy got the invoice.
So Mr. Jack. How are we getting on with Evo EQ graph?
Just my 2cents, but I think in this day and age of everybody doing and sharing their own FR measurements, the one from manufacturers are not as relevantTake for instance Crin's graphs. He is very transparent about his setup which anybody can buy, and also resonance peak in his measurements as an artifact of that specific coupler. But what makes his measurements standout is having a huge database to use for comparison. People don't just look at the graph, many use it to compare one IEM to the other. And comparison only makes sense when it was taken in the same setup, so you can look closer at the difference. Otherwise, I don't think it will make sense to compare, as an example, EVO's FR graph from Dean vs half a dozen of different LX measurements from other reviewers, all with different setups.
Good point-but regardless of measurement scale and setups, if Dean/Jack provided a graph comparing LX/LXSE/EVO on their own terms, it should help paint enough of a rough tonality-picture for most of us I think.Just my 2cents, but I think in this day and age of everybody doing and sharing their own FR measurements, the one from manufacturers are not as relevantTake for instance Crin's graphs. He is very transparent about his setup which anybody can buy, and also resonance peak in his measurements as an artifact of that specific coupler. But what makes his measurements standout is having a huge database to use for comparison. People don't just look at the graph, many use it to compare one IEM to the other. And comparison only makes sense when it was taken in the same setup, so you can look closer at the difference. Otherwise, I don't think it will make sense to compare, as an example, EVO's FR graph from Dean vs half a dozen of different LX measurements from other reviewers, all with different setups.
It would most likely displace the V14 to be honest to join the Wraith and Odin.Jump on that … just kidding! If you get the EVO, would you keep your Odin since I’ve read how much you like it?
I bought my Odin FE blind, but I’ve decided I will need to hear the Evo before I buy it. I’m a little concerned whether the sub-bass may be too much for my ears causing fatigue.![]()
Cannot agree more. Thats why originally i asked fir both LX OG and Evo graphs together, just did nor mention now because someone else already requested the same.Just my 2cents, but I think in this day and age of everybody doing and sharing their own FR measurements, the one from manufacturers are not as relevantTake for instance Crin's graphs. He is very transparent about his setup which anybody can buy, and also resonance peak in his measurements as an artifact of that specific coupler. But what makes his measurements standout is having a huge database to use for comparison. People don't just look at the graph, many use it to compare one IEM to the other. And comparison only makes sense when it was taken in the same setup, so you can look closer at the difference. Otherwise, I don't think it will make sense to compare, as an example, EVO's FR graph from Dean vs half a dozen of different LX measurements from other reviewers, all with different setups.
Quick question for LX users: has anyone tried both Azla Crsyals and Acostune AET07 tips with LX? And if so, how do they compare in sound and comfort?
Sure...go for it.I can probably share an opinion on this from a Bravado Mk2 perspective?
Fully agree, I own both Empyrean and UM Mason Fusang, after I got my Fusang, Empyrean was sold week after, there is simply a big difference in sound level you get, if you like Empyrean after some revolutionary hi-end IEM, then someone has chosen a wrong IEMI’ve heard both. Most IEM’s up at the LX level and beyond are more technical than the empys. The empys are warm but they do lack a decent amount of detail retrieval.
Sure...go for it.
