GiullianSN
Local dealer already selling the custom version. Just opened a Saving Account for that. lolAnyone else besides me just waiting for custom version of Odin cuz they just have 0 tolerance with EE’s UIEM black shall?
Is the 1950s copper as well? Odin comes with a 2-wire.
I know you have the 2-wire with your Zeus - did you notice any changes over time with burn in?
Please do. let's chat ..I may have to PM you on some of this stuff if I get serious about an upgrade. I have been thinking about a new DAC, but have been spending on my IEM’s. Tks.
I also bought mine used, but have no idea how used. I thought it was peaky in the treble when I first tried it, gave it about 15-20 hours burn-in on the Zeus and it sounded, to me, much better.i bought mine used so not sure , but i feel like it got a bit better after 50 hours
memory in this hobby is a bit tricky as you know yourself , jut burn it and see if you are satisfied with it after some time , if not sell it and buy something else ?
Yeah I would say my ears are normal size but I personally prefer a tighter fit for my IEM.Now that
Do you have smaller ears? I wondered about how the fit was going to be since the Odin is my first EE product. My ears are on the larger side, usually wearing a final E ML tip size.
Headphones and Personal Audio with Pitch Perfect Service.
Stay updated on Bloom Audio at their sponsor profile on Head-Fi.
Nice, is that the Noble cable? How does it sound vs the PWA?Odin + Vivid
It sounds amazing. I wouldn't recommend the look for your commute though. I can't give a fair comparison though because I was using the 3.5mm Vivid vs. the 2.5mm Stormbreaker on different sources (DX220 Max vs. SE200). I was hearing a bit more low end on the Vivid than on the Stormbreaker, but I'm not sure how much of that was due to the DX220 Max being a bit warmer than the SE200 to begin with.Nice, is that the Noble cable? How does it sound vs the PWA?
Thus the slippery slope of cable "upgrades" and incorporating many factors, ie. multiple sources, different outputs etc. It is a hard pill to swallow for anyone that realizes cables are the last tweak, and produce minute changes. The Vivid cable is another $1260 on top of $3400 you spent for ODIN which included a $1300 Stormbreaker. Gotta love this hobby.It sounds amazing. I wouldn't recommend the look for your commute though. I can't give a fair comparison though because I was using the 3.5mm Vivid vs. the 2.5mm Stormbreaker on different sources (DX220 Max vs. SE200). I was hearing a bit more low end on the Vivid than on the Stormbreaker, but I'm not sure how much of that was due to the DX220 Max being a bit warmer than the SE200 to begin with.
I have to ask. I just got the SR25, but didn't expect to get the Odin's. If I decide to upgrade DAP's...... The DX220 Max or SE200? How close are these to the AK 2000? Thanks.It sounds amazing. I wouldn't recommend the look for your commute though. I can't give a fair comparison though because I was using the 3.5mm Vivid vs. the 2.5mm Stormbreaker on different sources (DX220 Max vs. SE200). I was hearing a bit more low end on the Vivid than on the Stormbreaker, but I'm not sure how much of that was due to the DX220 Max being a bit warmer than the SE200 to begin with.
Used the SP2000 extensively and owned it on two different occasions, IMO SQ alone... DX220 Max > SP2000. Both have their pros and cons.
many feel that the DX220 Max is the best sounding of all the DAP's.
Please do the Lurker FW upgrade on the MAX! Gives a huge improvement.
I'm interested to hear more about the performance of the Odin out of the SE200 when you manage to get more test hours on the setup.
Thanks in advance!
