Shredicus
- Jul 7, 2011
So I got one of these bad boys as an upgrade from my Magni 3. There is a greater noise floor from the A-100 (it is an 8 Ohm output impedance after all) so I'm thinking of keeping my Magni 3 as a pre-amp to the A-100 (to help moderate the extreme volume potential of the A-100 from my computer) and then so I can use the Magni 3 with any lower-impedance headphones I come into. Does anyone know of any drawbacks to using the Magni 3 as a pre-amp to the A-100?
As for impressions; the difference in dynamics between the two is quite palpable -- after volume matching and quickly A/Bing between the two (while using the Magni 3 as a pre-amp -- not sure if that would skew the sound or not, I can't admit to telling a difference straight from source); on my K7xx, bass is much more authoritative, meatier, the Magni 3 sounds shallow in comparison. On my HD600 everything is cleaned up, instrument separation is stronger; on ruckus-y tracks where the snare would get lost on the Magni 3, it punches right through the noise on the A-100. On my Ether Flow C's, bass slaps haaard compared to the Magni 3, and the mids (my biggest beef with the Ether Flow C's is they sounded a little hollow) have much more body and weight to them.
I'm also considering selling my Magni 3 and EL DAC for a DAC/amp that can output RCA, so if anyone has any good suggestions for a product that fits that bill for around, I dunno, $250, it'd be much appreciated! (I was thinking, maybe the Aune X1s...)
Actually the with the jumpers installed output impedance is near zero according to Keith from Emotiva. It's 220ohms with the 220ohm resistors unbypassed.
