Just found how good this amp really is:
1) It's not the noise from this amp that being heard. It's the amp being so transparent, that tiny bit of noise from my source was carried to it and heard.
After I spend many days trying to figure out the noise, I finally located the noise. So this amp really helps me improve my signal chain to a higher level of purity.
I improved my computer to elimate the long heard noise that I initially thought was brought by this amp. Cuz I hadn't heard that kind noise before I purchased this amp, so I really initally thought it's the amp causing the noise.
2) The two adjusting knots in this amp can adjust the portion of tremble vs. Bass. This is very help to set the sound to my like. And I can change the sound a lot to tune the sound to my like.
It's not until many days of usage that I found this hidden feature.
I have ordered a Bottlehead Crack in the days that I thought this amp is causing the noise issue. Maybe I will compare this amp with the BHC.
