I modified my Campfire Audio Stock cable - ALO Audio Litz cable (From 3.5mm to 2.5mm and removed the earhook), is it acceptable for trade in?
Effect Audio Trade Up Program
- Thread starter EffectAudio
- Tags
- cables effect audio
Easy peasy, buy some new IEMs.For this price its definitely worth seeing if I can scrounge up a stock cable. Which might be an issue....
KuroKitsu
Ha, if I get the Phantom in a weeks time, Im saving that Aries II for the upgrade to an Eros II 8. That said, I actually dont have a single stock cable at all . Guess I hope the Origin doesnt sell out before payday.Easy peasy, buy some new IEMs.
rendyG
Hi, what should I send as a "proof of your shipment information"?
I live in Czech republic and I can't ship the stock cable with tracking. Is it okay to send it as a "normal" package?
significantly improves the sound quality
Cool!
ty777
Great program! Aside from the sound, It's a nice looking cable anyways.
justrest
I just ordered. Let's see how good it is.
TooPoorForHiFi
Previously known as MidNighTempest
Hello I am interested in the Trade-In Program for the EFFECT AUDIO "ORIGIN" Cable.
I have a Question:
Am I able to trade in Multiple Cable to get one without Paying the $50 or lesser?
I have a Question:
godlikegamer
- Apr 4, 2015
I have a Question:
I dont think so... Since $50 for EA is actually quite a deal...
BananaOoyoo
Am I able to send in something like a KZ silver cable? It's technically an "upgrade" cable, but would be cool to try out the Origin.
- Jun 20, 2010
Does this cable fit the qdc Neptune? It has reversed polarity extruded 2-pin 0.75 mm connectors. What do the connections of this cable look like? Will they stick out further than normal because of the extruded portion?
godlikegamer
- Apr 4, 2015
Hi, ur QDC has .75? I thought QDC uses .78? I think this cable is .78 it stated 2pin instead of .75.. IMO is not advisable to use normal 2pin on extruded...
- Jun 20, 2010
I measured them at 0.76 mm. I also measured a 0.75 mm cable at 0.76 mm. The fit is the same, slightly tight, with both of them. 0.78 mm would be too tight.
- Sep 20, 2016
Yep that will be possible!
Unfortunately no, we do not have the Origin in reversed polarity. The Origin 2Pin is the usual 0.78mm. We currently only support 2Pin/Mmcx ; 2.5mm/3.5mm for the program
Stay updated on Effect Audio at their sponsor profile on Head-Fi.
@EffectAudio very interested in taking up the offer. I had two quick questions:
- I have an IEM that came with a balanced all copper cable rather than stock cable. Can I trade that in?
- Is it possible to select express shipping (eg., DHL or FedEx) as an option as any other postal service isn’t reliable here in my country.
Thanks!
Thanks!
