edwardsean
- Jul 7, 2006
Thanks for the reply. I figured there would be no issue but I wondered at the difference when going from a sensitive iem to a larger driver if something gets lost in the translation. I would be getting it reterminated professionally with quality connectors and Mundorf solder so while the sound may change somewhat, hopefully a lateral change rather than a degradation.
The connector will alter sound signature, but if your system is not deficient in some way, a few degrees in any direction is fine. To my mind, the performance is more important. At this level, it's worth the extra for the best connectors. I have gone through every good to great connector. Oyaide is excellent, Furutech (CF–R) is best. It improves SQ to my ears.
The solder also makes a difference to be sure. I use Oyaide, WBT, but stick to Mundorf (silver/gold) for cabling. The connector and its conductor core is much more important.
