If this connector is like other 3.5mm + 2.5mm AK connectors made before, it actually uses the ground from the 3.5mm so you can go fully 5 pin 4.4mm connector and connect to balanced amp for example.
Yes, if I am not mistaken then @ThomasHK is correct about this. If you look closely at the 4.4mm connector, there are 4 poles, while the 2.5mm connector only has 4 poles. Thus, this adapter from EA uses the 3.5mm as an active grounding, which effectively uses the 3.5mm as the "5th pole" that is missing from the 2.5mm connector to make it fully balanced. So in this case, you should theoretically be able to get the actual sonic benefits of the 4.4mm over the 2.5mm balanced plug. This is unlike the "balanced adapters" you see like the one pictured below!
Am I missing something here ? don't balanced adapters already exist for just $9
www.Amazon.com/dp/B081C3M5RB
Also, EA uses the PSquared 2.5mm and 3.5mm and the Pentaconn official 4.4mm socket. A quick google search will show that these individual components are not cheap. I don't wish to comment on the pricing, nobody would be able to tell you if there will be an improvement in the sound or not, that is up to each individual to judge and decide whether they are able to hear the differences for themselves and whether they are willing to pay the price for it!
I personally would also hope for AK to adopt the 4.4mm plug in their DAPs but I highly doubt it would happen
