Wow, I haven't check this thread since it was a couple of pages long. Nice stuff here. Here's some info you guys might find useful in your quests.
Here's the procedure to match the ZD rectifiers by ear.
Quoting Craig;
I match the rectifiers when the amp burns in. I look at the first filter after the rectifiers. This wave form should be 120Hz sort of triangle looking with even peaks. If the peaks are not even the tubes don't match. This is the best test because the tubes are loaded with the actual current the amp is running steady state.
You can test by ear. Power the amp up, and with the volume full counterclockwise listen for background noise. You will need sensitive headphones, like the RS-1's. Pull one rectifier and listen. You will hear a pronounced 60Hz hum in both ears. A tube mismatch will be between this level, and no hum. If you hear a hum with one rectifier, but not with both, they are matched close enough.
Before you guys ask, this procedure is all done with the amp on. I let the amp warm up for 30 minutes. Use a pot holder to remove the tube (don't remove any tube except the rectifier, either one will do). When Craig says that you'll need a sensitive pair of phones to hear the hum, he ain't kidding! This is one quiet power supply! The rectifiers are real cheap so the best thing to do is buy 4 and find the best two pairs among them.
Regarding the differences between Phillips tubes, pay less attention to the label and more to the country (factory) it was made in. There are variations (within a given production year) in materials and assembly from factory to factory (plate, filament, pins etc.) but if it's a 6sl7 and it's made in the same factory, it's the same tube. So if a tube has a delta code, then they were all made at the Heerlien plant in Holland and labeled depending on distribution. If they were made with a different design, they carried a different tube type name (VT229).
Here's a great link for identifying and reading date codes on Phillips and Siemens tubes;
Tube Classics - Audio Tubes
You should seek out these data sheets to reference when buying NOS tubes. Having these bookmarked will help you weed out some of the BS that some sellers will try to feed you.
