Ok, now we come across the problem I mentioned earlier. Mine and @assassin10000's tuning and shells are differentand here's the compensation file!
@furyossa, your n55 64ohm peq correction files normalized to my version 1.5 target.
This driver is mid-centric and my mod has a bit intimate sound with a narrow soundstage
In Peace, the preamp value is set to -6dB. Also, I hit the "compress" button 3 times. Without compression, the sound is sharp and occasionally sibilant.
With 3x compression is very similar to my previous WIP tuning, also Sam's PEQ file has a better vocal presentation and balance in general, while my version has a slightly more pronounced low end.
"natural" version by @Sam_L (3x compressed)
Preamp: -6 dB
Filter 1: ON PK Fc 24 Hz Gain 3.18 dB Q 0.57
Filter 2: ON PK Fc 237 Hz Gain -0.15 dB Q 2.48
Filter 3: ON PK Fc 247 Hz Gain -0.51 dB Q 2.29
Filter 4: ON PK Fc 834 Hz Gain 0.66 dB Q 3.12
Filter 5: ON PK Fc 2062 Hz Gain -4.1 dB Q 1.41
Filter 6: ON PK Fc 4606 Hz Gain 3.54 dB Q 1.15
Filter 7: ON PK Fc 7138 Hz Gain -3.18 dB Q 3.19
Filter 8: ON PK Fc 9145 Hz Gain 1.88 dB Q 2.06
Filter 9: ON PK Fc 12496 Hz Gain 1.58 dB Q 1.12
Filter 10: ON PK Fc 16874 Hz Gain 2.51 dB Q 0.72
"bass" version W.I.P
Preamp: -6 dB
Filter 1: ON PK Fc 12 Hz Gain 5.4 dB Q 0.9
Filter 2: ON PK Fc 40 Hz Gain 5.4 dB Q 0.56
Filter 3: ON PK Fc 187 Hz Gain -0.7 dB Q 0.49
Filter 4: ON PK Fc 241 Hz Gain -1 dB Q 3.04
Filter 5: ON PK Fc 829 Hz Gain 1.4 dB Q 2.85
Filter 6: ON PK Fc 2059 Hz Gain -8 dB Q 1.43
Filter 7: ON PK Fc 4596 Hz Gain 6.8 dB Q 1.18
Filter 8: ON PK Fc 7136 Hz Gain -6 dB Q 3.27
Filter 9: ON PK Fc 9194 Hz Gain 3.8 dB Q 2.07
Filter 10: ON PK Fc 12644 Hz Gain 3.3 dB Q 1.11
Filter 11: ON PK Fc 16952 Hz Gain 4.8 dB Q 0.74
DaturaPro vs 64ohm N55
N55 has rolled-off sub-bass and mid-bass is a bit shy.
Mids are positioned properly, the separation between instruments and vocals is good for intimate sound, treble is smooth and not offensive.
DaturaPro has a better bass extension Sub-bass and mid-bass complement each other perfectly. The bass is not overemphasized but discreet.
Unlike N55, DaturaPro has a specious sound. Mids are nicely defined with good clarity, and even better positioning and separation in 3D space.
DaturaPro has a better treble extension. The details are clear and accentuated
These are of course first impressions. It takes a little more time to test with different music genres to see if a correction is needed elsewhere.
For now, the impressions are positive and above expectations
