Skull, I got 17 hours on them and I couldn't help myself but do an A/B of the TK12 and the SW III. It's NOT my fault. They were calling to me: TWIN LISTEN TO US, NO ONE HAS TO KNOW....
What I'm finding is they have a similar Uhhhh.... HOUSE Sound. Yes, That's the word I'm looking for. The MAIN differences between the 2 Is the Clarity and Resolution of the Shockwave. Now Even though the TK12 sounds a little Bigger because of the elevated Bass I Swear the Shockwave has quite a bit more Extension on it's Bass, I mean it goes WAY down.
I'm thinking that the reason the TK12 sounds larger however is simply a Matter of it being easier to drive therefore it's Louder at a set volume. When I bring each earphone up to a similar Volume according to my hearing they Both sound equally Huge. Maybe with a nod to the TK12 having a little more Fullness but the SW III having much more "Audiophile" type fidelity.
I just can't get over that 2 B/A's can make THAT much difference in Resolution. I'm pretty sure the Crossover in the SW III has a LOT to do with that though. Instead of all the drivers being their full ranges there are slopes and cutoff points to dedicate separate drivers to certain pre-determined frequencies exactly as a crossover is meant to function. This is a full electronic crossover network BTW, not just a couple resistors placed at strategic points.
Since WE are the only 2 that own these as of right now please let me know if you agree with what I'm hearing.
Back to the Burner Now. This is going to be
HARD leaving them alone......
TWIN
