Infoseeker
On that note,In case you were referring to my post, to be fair I already have three desktop DAC/Amp pairs, so the only use model I personally am interested in for the 9038s g3 is the mobile one (either from my cell phone or DAP), hence why of all the improvements, those two in particular get my attention. I am certain the 9038s is brilliant for those who use it as a desktop setup, but as I mentioned, not my particular need.
E1da is releasing a dac-only version of the 9038.... Called the 9038ap.
The concept is:
"AP" stands Audio Precision i.e. the same as the most precise and expensive audio-analyzers from a famous US company. This is not just an accident, 9038AP has a distortion analyzer on board working in the same principle like APx555 and so on(notch+FFT). You can test the distorions of 9038AP with a crazy precision(V02 proto version can see 3rd harmonic at -127db, and I prepared the improved one V03 with hope to hit -135db) any time you wish, readjust that for any particular headphones(you'll see online with 9038AP BLE Android/iOS app how different HP affects the distortions), and save that like a preset.
Inputs:
USB-C PCM 32/384kHz DSD256
Optical SPDIF/Toslink 24/192kHz(combined with 3.5mm jack)
Bluetooth Low Energy(BLE) to control the DAC and THD analyzer(DSP involved)
Outputs:
XLR balanced 3-6VRMS
3.5mm jack unbalanced headphones output 3.5VRMS >500mW@16ohm
Additional USB-C connector for power only, you can use 5VDC charger and so on.
The mainboard is ready to be a single either dual configuration of ES9038Q2M DAC(to eliminate the mutual disturbances, the idea of small modules is implemented), also, I want to make it able to use with a single ES9038Pro.
I like the idea to supply that product just like a board to avoid production issues with decent looking housing.
The price is TBD but I hope the single ES9038Q2M will be $100.
