lxlx
- Mar 15, 2010
Sure they did, but I think it's funny that Shanling offers a FiiO productSeems they misunderstood you. It is not right-angled. https://penonaudio.com/fiio-lt-tc1.html
I've had no problems with it.
I haven't done an exhaustive battery test with it but I've listened to that combo for 5 hours in one sitting, not sure how much battery was left when I had to turn it off.
Thanks! That's enough information for me, can't wait for my V1 to arrive....
nice, i search for warm sound. will the 9038 will good?
Is there a serious difference in sound between the player itself v1 and the extra duck mode?
I am a new owner of the 9038s and the PoweDAC.
Lots of great things are written about these so I won’t repeat those. But nothing is perfect and each of these products have something that might disqualify them for some people, and I want to make sure these issues are clearly stated (yes written about elsewhere but since this thread is 30 pages, and almost all of them filled with tributes, sprinkling in every now and then reminders that nothing is perfect is probably a public service )
For those considering the 9038s as a portable DAC / Amp to run off their cell phones, this is a great solution... but... if you are someone that highly bothered by interference noise, and you want to use the 9038s with your cell phone, don’t get this. Seems that cellular signals (but at least for me not WiFi) are picked up as pops, crackling, etc. I am fine as I don’t hear it when playing music at reasonable levels, but I know for some they will consider this a disqualification - pages and pages of complaints about interference is written about on some DAP threads about interference with particular DAPs, so I know this really bothers some people.
For those considering the PowerDAC as a desktop / transportable solution, it is great! But, one major flaw. The PowerDAC will revert to full power when it boots up. You have to go into the Bluetooth app (it is controlled via a Bluetooth but does not play via Bluetooth) and lower the volume. You will be blasted by VERY LOUD sound if you forget. Like I have. Multiple times.
I will have to try that!!!There is a workaround for that if I remeber...you save a low volume preset as default.
Soooooo, just got a custom shells pair of Musicmaker BL1 planar magnetic IEMs...truly stellar out E1DA un-EQ'd...natural side of neutral tonality...great micro-detail transmission and imaging...'headstage' comes out just kind of in front of face where I like it.
You need to tiproll though, as most know, stock tips usually hold back the full potential...very transformative with that...Great sub extension and instrument decays indicate the sweetspot.
I may mess around with longer bore spinfit tips as I think that works better with planar IEMs overall SQ...
Looking forward to 9038S V3 so I can appzap soundflowerpot on MacOS re. volume control systemwide..
Nope, thing I like about the planar IEM deal is one driver for coherence across the delivery.....dat planar presentation....I can endure a higher amount of treble off these vs most lower priced BA treble...as a bit treble sensitive...hence liking mono 1060C planar...LCD2C etc...Have you ever heard the **** MT100?
The decays on BL1 remind me of LZA2 which had something special in that region....a lucky accidentand 9038S holding nothing nor adding any brittleness like old school 9018 Sabrezzzzzz.
Extended and controlled un-EQ'd vs impact at my listening levels. Am going to do the sponge mods on all ports maybe.Thanks! I really enjoy the MT100 and have always been intrigued by the BL1, just afraid they're to similar. The MT100 is really flat (probably the most flat, in a good way, I've ever heard) with bass that goes deep but it does lack some impact, how's the bass impact on the BL1?
Sorry for the OT but I do plan to use them with the 9038S
