I saw that one and I still can't understand how noone sells similar cable. So far I've only seen one on taobao, but I have no experience with forwarding companies..
I even messages a few sites which makes custom usb cables, nothing.
finally found a workable portable cable solution that works for me -
It's a 90 degree USB-C to 90 degree micro USB cable that came w/ my xduoo XP-2. It's fairly easy to find small usb-c to micro-usb cables on e-bay and the likes, but for whatever reason usb-c to usb-c is a unicorn. So I created my own by using a compact dongle to convert the mini-usb side to a usb-c. The cable is designed to bend 180 degrees so this setup easily slides in my pocket & sits nearly flush w/ the phone.
Interesting stuff, strongly considering pairing the pdv2 with my ex1000 since i only use it on my desktop and according to the first post, has presets for ex1k? Anyone ever paired them do share your views on it, or any iems with peaky treble for that matter
I arrived at a similar solution, only with the Fiio usb c to usb micro cable. I am happy with it, but still don’t understand why no one is making a usb c to usb c L shaped plug.
I haven't done an exhaustive battery test with it but I've listened to that combo for 5 hours in one sitting, not sure how much battery was left when I had to turn it off.
Anyone use an adapter like the one that comes with this Nintendo Switch Bluetooth device?
US $1.51 | 90 Degree Type C Adapter, USB C Male to Female Adapter Upward and Downward Angled USB-C Adaptor USB 3.1 Type-C Connector https://s.click.aliexpress.com/e/qtnbwOWM
