Extrasensory
I have been keen on buying the PowerDac V2, but I am waiting for 11.11 festival to see if the price goes down.
got it to finally work with the instructions thanks
I really don't like providing access to those options for any of my apps during the install process which is why it didn't work. Plus I usually don't have location services on unless I need it as it chews battery life. But once I re-installed HPToy with all those options the device showed up and I was able to enable the P1 Harmon filter and wow. Listenning to via audirvana on my PC on a DSD/DSF recording of "On a Clear Day" by Emilie Claire Barlow and some discovery albums on Qobuz I finally was able to see the TIN P1 shine. I think with this kind of power it outshines the Tape which has some challenges in the high end. Although on low power DAPs the Tape is a better option like the BLON 03. Two amazing little devices to carry around. Anyone do a comparison the 9038 to the Cobalt/Red/Black yet? Although based on how those work you could say the PDV2 is also a competitor just a little larger
Thanks for the help really appreciate it
is that a sony powerbank?
If so i have all three of those devices and will try that combo
at this point I've just been using my Hiby R3
Which amp has 2.5mm BAL in? Would love to know.
User @Ikety shared a possible workaround to gain 9038S volume control in Macs using Soundflower, tweak at your own risk:
https://www.google.com/amp/s/macintoshhowto.com/audio/how-to-adjust-the-volume-of-a-usb-audio-device-in-osx.html?amp
why wider selections? because it is more common to have an 3.5mm imput like the Atom?
but if I can connect the PDv2 to the Runabout I will stuk with that for a long time, and also use the PDv2 as portable solution with all those features
Hard for me to believe you are going to get much more out of the runabout than straight out of the PDV2... Or is it just to be able to use headphones with an unbalanced cable? I've experimented with the pdv2 as just a dac, outputting in balanced to the ifi XCAN, and it was just okay, certainly not any noticeable improvement over the pdv2 on its own - even with the extra power. BUT! The 9038s > XCAN worked really, really well.
If you're looking at E1DA for just the DAC ability, I would go with a 9038s/d instead of the pdv2.
Been running this set up for years, there is no risk. You can use system settings/audio midi setup to adjust the output level - but the best way to use soundflower is with something like hosting au: http://ju-x.com/hostingau.html
This way you can fine tune the output, as well as use all the audio plugins (gEW/pEQ) and any other plugins you may have downloaded. This is really the best way to EQ sound on a Mac, especially if you stream music from spotify/tidal/qobuz etc and aren't using a music player with good built-in EQ.
Your missing out on Audirvana Plus then on MacOS, as no player I've used sounds as good as A+.Thank you, I don't listen music much on my mac (I prefer on the couch/bed with my phone or tablet so your advice is priceless. I will add this answer to first page FAQ and tag you, if you don't mind.
