DX320 ROHM dac chips, Android 11, AMP11MK2s. *******NEW FW: 2.07*******
Sep 1, 2024 at 2:38 PM Post #10,412 of 10,576
It's just a visual indicator glitch, once you unplug it and plug it back in it should update with 100 percent on both sides.
I did this and the percentage is the same, I turned on the device and it shows the same percentage
Sep 1, 2024 at 2:42 PM Post #10,413 of 10,576
I did this and the percentage is the same, I turned on the device and it shows the same percentageIMG_5603.jpeg
It might need a full discharge then and a full charge to reset the battery.
Sep 1, 2024 at 6:29 PM Post #10,416 of 10,576
Hello, I have just bought a used DX320, I charged it with a GAN charger when D battery was around 30% I left it for two hours and it was 80% on D and 84% on A battery, I let it charge for another hour and the percentage was the same. I turned the player on and checked if the limit to 80% was activated but it wasn't. Is this normal or are the batteries defective? IMG_5597.jpeg
You need to go to settings and turn of battery saver - when it's on, it will always charge only up to 80%, even when you are charging while it's turned off (analogue battery often goes slightly over 80%). I used DX320 with battery saver on and it looked exactly same.
Sep 7, 2024 at 8:26 AM Post #10,421 of 10,576
Ah OK, cos you mentioned the word 'confirm'. Which no one can really confirm for us.
To me, the 300max sounds more neutral and the 320 leans more to the warmer side. It's not a warm player but 'warmer' in comparison. Both TOTL sound.
Both to my ears have excellent technicalities. But if I was to choose one player for technical side, I would choose the 300max.
It's marginal to my ears, however. It's not night and day difference. Subtle. To me you only pick it up in a direct A to B. But even there it's not a blindfolded test so I could also be 'hearing' with my eyes as the 300max looks flashier so my brain may interpret that as better sounding. Or vice versa..
Dunno if that answers your question.
I know that myself, that's why I'm asking for opinions.
Sep 7, 2024 at 12:06 PM Post #10,422 of 10,576
Can anyone else confirm that the DX300Max sounds technically better than the DX320?
i will say the the 300Max has a slight edge in sound over the 320 to my ears ( using stock amp11) Just brings out a little more of the micro details. But this is subjective depending on everyone's sound preferences / headphone / gear etc. I found this true on multiple headphones, but it was not night and day over the top.
I ended up using the 320 more for features / amp selections and sound tuning was just more fun. And its a little more portable than the 300max.
The 300max is heavy and basically sat on my desk. I prefer the DX320 size and modern screen to body ratio a bit better.
And with the 320 Amp modules you can tune the signature with options that you can not do with the 300Max.
Sep 7, 2024 at 12:36 PM Post #10,423 of 10,576
Great, thanks for the answers!
  • Back
