I use the amp13 the right output
DX320 ROHM dac chips, Android 11, AMP11MK2s. *******NEW FW: 2.07*******
- Thread starter Paul - iBasso
- Tags
- ibasso ibasso dx320
jamato8
Or give it a day or two. Or use the 660 tool. I find that my perception/subjectiveness changes but that there is a point upon which, over time, I can agree on. :^)I will try thank you. What bothers me is that the bass is much stronger and it bothers me a bit. Either it's me or my brain, I don't know. Otherwise someone would have a pmeq to lower the bass impact. thank you
ipaddy
human bean
Something is wrong with Head-Fi. I get intermittent Server Errors connecting today.
bflat
Another possible explanation is volume matching. For me, I am more sensitive to sound at the beginning of the day so I dial down volume 5-7 clicks lower than later in the day. If I forget to dial the volume down before I go to sleep, the sound in the morning to my ears sounds bass heavy until I lower volume, which then makes treble sound rolled off. It takes a few hours in the morning for my hearing to balance out.I will try thank you. What bothers me is that the bass is much stronger and it bothers me a bit. Either it's me or my brain, I don't know. Otherwise someone would have a pmeq to lower the bass impact. thank you
True, this time I didn’t bother listening until after multiple restarts.Try restarting the DX320 a few times. I don't know why but it can change the sound. Then there is the 660 tool on the 1st page and you can use that on a PC to change to an earlier version of firmware.
I ran into similar issues noted in this thread with Google Play incompatibility. But I am pleasantly surprised Amazon music installed via APKpure works without issues.
Layering, imaging, and space between notes with FW 2.04 are noticeably improved via SE connection over balanced connection in previous FW. The thing that is striking is how well controlled instruments sound even on sustained complex passages or recordings.
I must be in for a treat with balanced and FW 2.04.
- Oct 14, 2013
I can agree with this on Amp13. Whether one like it , that depends on personal preferencesI will try thank you. What bothers me is that the bass is much stronger and it bothers me a bit. Either it's me or my brain, I don't know. Otherwise someone would have a pmeq to lower the bass impact. thank you
DAPpower
Hmmm, am I the only one that likes the previous firmware SQ?
I feel like the latest one sounds a bit too dense and thick with more bass....
- Oct 14, 2013
Agreed, and you are not the only oneHmmm, am I the only one that likes the previous firmware SQ?
justsomesonyfan
- Sep 24, 2013
@Whitigir think the amp14 can take over the wm1am2's place for you?
Previous FW had an obvious bass shelf in the sub-bass region and mid bass is comparatively recessed. New sound signature is more linear in the bass region and mid bass will initially appear more prominent, which it isn’t. I feel like 2.04 is closer to the native recoding.
I have only done a brief listening session with one IEM post FW upgrade and may have a different opinion after listening the full gamut of playlists and headphones that I use for evaluation.
- Oct 14, 2013
Not sure, haven’t heard the amp14 yet. But the DX320 can and can surpass other flagships for sure. It has great potentials.@Whitigir think the amp14 can take over the wm1am2's place for you?
justsomesonyfan
- Sep 24, 2013
iirc you said rohm is the #1 dac, so the potential is definitely thereNot sure, haven’t heard the amp14 yet. But the DX320 can and can surpass other flagships for sure. It has great potentials.
