- Oct 6, 2013
Using the DX320 with wireless iem's and headphones.
I believe that usually there isn't much of an advantage in using a superior DAP when using wireless than when using wired iems and headphones. I'm told that much circuitry is bypassed, and so we don't get so much difference (I'm not referring to the obvious reduction in quality caused by wireless--that is a constant, and assuming the same procotol is used, should not vary between daps).
Is this true for the DX320? For example, using an excellent wireless headphone like the PX8, can one expect as much of a difference between using the DX320 and, say, the DX170 or even an old FIIO M11, than the difference when using a wired headphone?
That is correct, with wireless you are bypassing most of the ckt in the DAP that differentiates it from your smartphone since you don't need digital to analog conversion, amplification, filtering, etc. For the best wireless performance, especially tws, if it is a priority to you - use your smartphone. They are optimized for that specific functionality, including more powerful wireless signal to cover bigger area. With most of the DAPs I tested, wireless distance is shorter in comparison to my Galaxy S22. DAP will offer a better power supply filtering since it has more room for the components, but in a digital domain with all the error correction not sure if that has much benefit since the conversion to analog is done in your wireless headphones/earphones.
