- Oct 14, 2013
A couple feedbacks from using edition X as daily systems
1/ Leather case is nice and comfortable, but it makes the player a lot more bulky…thicker…longer…wider. Mostly is that it is kinda loose after a few time taking it in and out to swap amp modules. So, if you like to use the leather case. I recommend that you decide to stick to one module for a while to avoid taking it in and out. If you have yet to decide, don’t use the case.
2/ The player is designed for the phone outs orientation to be on the bottom. Naturally, if you use it inside a pocket, you will have a little uncomfortable feeling as you do not want the plug to go down to the pocket bottom. You will want it to bottom up!
From #2, you will want to use AndroidOS with screen rotation in case you like to browse around from time to time. Otherwise, if you are organized, you can use MangoOS with the player inside the pocket, the bottom up, and use side buttons. The side buttons on the X is nicer as the curves hides it a little better that you don’t accidentally touch it like the original (without the case)
So, overall, I think the X is a lot better to be used without the leather case. And in AndroidOS, do use neutron newest versions for the best performances
*Amazingly doing Upsampling 16X into 768Khz with Class A discrete and inside the winter jacket pocket, but only comfortably warmed up* and not burning hot. Can not say enough how amazing this is
