legabian34
https://neutroncode.com/faq/58-empty-mlibThat is what I'm doing but still doesn't recognize any song, I dont know if still reading the card (almost full 1tb) so I will wait a bit, thanks.
If it can help
From looking over the pics, I would say it's a definite game changer, for the amp13 board.My interest in AMP13 has been rekindled
He says 'its work in progress but sounding great so far'
pics nabbed from over at np
Exactly!:https://neutroncode.com/faq/58-empty-mlib
If it can help
I had the same issue and just reinstalled the version from the Neutron website and all was well. This lets you use the SD card as normal without going through the Scoped Storage file access API for Android 11. You can use the + method as others have mentioned to manually add a directory but I found that didn’t play nicely with the playlists I had already created. Reinstalling the APK from the Neutron website on top of what was already on my DX320 fixed it all and playlists are working correctly now.I finally updated the 320 today but Neutro doen't recognize my SD card, anyone knows how to fix it? When I go to Media Library > Sources > File System it only shows Internal storage...
Perfect description of DX400 isn't it Ibasso? or 320 maxI am going to share my audiophile dream with you here.
Maximizing ROHM chips
2X ROHM
5 batteries (like Max), with the optional features to run off from external PSU
Improved super class A amplifications with polymer and foils capacitors. Using MUSE for IV and buffers
Dual Korg tubes
2X MicroSD card slots
Passive - Liquid cooled back plate toward ROHM, SOC, Korg tubes PSU (custom made chambers and tubing)
SOC Snapdragon 780
AMOLED screen
*** feel free to add in more desires ****
How many times did you come when you had the dream???I am going to share my audiophile dream with you here.
2X ROHM
Dual Korg tubes
SOC Snapdragon 780
AMOLED screen
Add user changeable batteries, and your on to something. And if the amp section has op amps, also make those user changeable. I would add changeable tube modules but I don't think that is possible at the moment.I am going to share my audiophile dream with you here.
2X ROHM
Dual Korg tubes
SOC Snapdragon 780
AMOLED screen
Seems sort of a N8ii & C9 together with a better screen and a faster CPU ...I am going to share my audiophile dream with you here.
2X ROHM
Dual Korg tubes
SOC Snapdragon 780
AMOLED screen
Why not right ?Seems sort of a N8ii & C9 together with a better screen and a faster CPU ...
Great ideas! Perhaps a solid connectors for batteries system will work out a lot better.Add user changeable batteries, and your on to something. And if the amp section has op amps, also make those user changeable. I would add changeable tube modules but I don't think that is possible at the moment.
User serviceable batts pretty much renders away ‘planned obsolescence’ by a manufacturer though. Probably 3-4 iPods around the house I could revive if I wanted to. Would be like a mini time capsule of the kiddos music.Add user changeable batteries, and your on to something. And if the amp section has op amps, also make those user changeable. I would add changeable tube modules but I don't think that is possible at the moment.
Pretty easy, only a few bumps along the processUser serviceable batts pretty much renders away ‘planned obsolescence’ by a manufacturer though. Probably 3-4 iPods around the house I could revive if I wanted to. Would be like a mini time capsule of the kiddos music.
Has changing the batts been looked at on the DX300 or DX320? It’s something I’ve thought about, as the 320 could keep my ears happy for a very long time….
For example, the batteries inside DX300 is already with Ribbon snap-in cables
So a user friendly replaceable batteries is very possible
I know we are discussing "dream" machines, and that would suggest future tech, but with user replaceable batteries, that is actually going backwards in time.User serviceable batts pretty much renders away ‘planned obsolescence’ by a manufacturer though. Probably 3-4 iPods around the house I could revive if I wanted to. Would be like a mini time capsule of the kiddos music.
2X ROHM
Dual Korg tubes
SOC Snapdragon 780
AMOLED screen
