Air-Air and AIR, everywhere !
A quick take is that the amp12 is still an upgrade over the amp11 MKII-S. A quick visual inspections indicating that the Amp11 MKII-S is tuned differently than the other amp11 MKII, it has Vishay Film capacitors, and Ibasso custom made Aluminum Foils bypass capacitors.
Amp11 MKII-S is Still impressively made, a lot of hand soldered components. Especially the works to place the newly developed film capacitors.
Amp12 is still an improve over Amp11 MKII-S. So, if you really want to squeeze every bits out of your new DX320, then you should opt for Amp12, perhaps buy as a combo. Staging will be wider, and more airy. I do not have any hisses in high gain, but I am using it with headphones, so your mileages will varies, and better heed that warning from Ibasso regarding gain level
Sound signatures wise. This is different than the Dx300.
The sound signatures is now more in line with the typical Ibasso that I have known and love from the get go, very detailed and neutral,
with a great amount of air to everything. Textures are vivid, aggressive, with sharp edges, and greatly extended trebles. Bass are tight, very well controlled, separations and transients are much better than Dx300. But what is special about it is the amount of texture vividity even to the subtlest details, the instruments housing resonances and reverberations are spot on. I would say that this one has more neutral signatures than the N8ii, but with a more forgiving trebles textures as it is denser, fuller, and also does not spit in your ears when you have bad recordings, but it will still make sure that you do realize that you are feeding it a bad recordings.
I can hear that specialty of
The ROHM chips which I suspected from N8ii, the wide bandwidth, excellent inner density, thick tonal balances but with dynamic and impacts, not simply just making sound in low-mid-high as a signatures, but rather more focused into the timbres dynamic delivery. **by using different modules** the tonal balances can be tweaked to one liking. I once said that N8ii had an amazing tonal balances, but thinking back and confirming with Dx320, I can confidently say that what grasped me
was the expressiveness of the timbres dynamic delivery. I also suspected that it was the result of ROHM chips, and here I can Confirm that you will also hear it with dx320. I don’t call it the ROHM signatures, rather specialty, because it signatures are both AKM+ESS together.
If you ever thought of Dx300 to have some hint of tubes liquidity and warmth, then the Dx320 is more like a very high end Solid State amp.
If you loved Ibass from the DX200/220 lines, you will not be disappointed, but I would say that this is Ibasso coming back and better than ever, you will definitely fall in love right out of the box. I know that I did and do!
Heat doesn’t generate as much as the N8ii, despite using the same dual chips set that are so power demanding and is Current output DAC chips. Defintely warmer than Dx300, but still comfortable in the palm
The N8ii is more musical, Dx320 is more analytical, but I would think that if you listen to a varieties like I do, the Dx320 while being analytical can also be very enjoyable due to the highs that is more forgiving toward the brightness of upper trebles in bad recordings (that is to put it politely).
N8ii will have dual Korg tubes, and Dx320 has swappable modules but can also be said to be a lot more powerful with amp12 (approximately 250mW into 300 ohms VS N8ii with 160mW into 150 ohms). You can not go wrong with the Dx320 since it also carry on with ROHM chips as the N8ii. Previously when we had no choice, the N8ii was an amazing DAP in my opinions, but now with the Dx320 also carrying out that ROHM DNA as said, the 320 is an easy choice to make, which is also half the cost!
Additionally, in the heat generations department, Dx320 wins! The N8ii can cook ! The Dx320 will not cook anything
in conclusion, I guess you already know that I am back and in love with Ibasso*. This addictive house sound is now Back and better than previously, carrying that ROHM-DNA! Lady and gentleman
Congratulations on an amazing release
@Paul - iBasso , this here is a winner
Finally, if you are on the fences about N8ii,
both still carry different house sound, but if you want that ROHM specialty (timbres tonal dynamic delivery), then you have no choices but only these 2 DAPs.
I recommend you to listen to both before you decide it, but Ibasso and dx320 is a winner . How ? Because tonal balances can be tweaked with more versatility on dx320 than the different features from N8ii, at 1/2 the price ? And Ibasso customer supports.
This out of the box impression will changes as this is just out of the box, but I doubt it would suddenly transform from a well groomed cat to a badly, furry, crazy looking cat either. So, I will not post any long impression for a while, because I am waiting for my DAP to be burned in, and enjoy watching, observing, how the cat is being groomed
![Headphone Smile :) :)](https://cdn.head-fi.org/e/headfi/smily_headphones1.gif)
. Then there are different modules to enjoy
