You will have to try factory reset in recovery mode. If you have updated your DAP in past with OTA updates I would use the 660 tool/Qfil to flash FW. This software-wise makes the DAP like new.Clearing data did not work(
DX260MK2 now Shipping! Easily replaceable battery fast and responsive.
- Thread starter Paul - iBasso
Did not updateYou will have to try factory reset in recovery mode. If you have updated your DAP in past with OTA updates I would use the 660 tool/Qfil to flash FW. This software-wise makes the DAP like new.
What do you mean exactly? When you scan media nothing pops up?I can not reach flac files in sd card when I use Mango application. No problem in Mango mode. Any idea?
holsen
Hey NeighborI just wanted to give you something to think about and you probably already have. The CAD dollar sucks right now. By the time you figure in the exchange rate and the shipping and the taxes you will have to pay GST and PST when it comes into Canada, you might be better off buying in Canada. Quebec Acoustic sells iBasso stuff and because it is out of province you will only have to pay GST and the shipping is free. Quebec Acoustic has the DX260 on sale now for $999.99 CAD or around $690 US. The DX340 isnt on sale, but it might be worth a shot to ask what kind of deal would they make?
Thanks for your note - I wasn't aware of Quebec Acoustic so, thank you for the heads up on them. I'll be watching. You're right it may be advantageous to buy domestically. Appreciate it!
darcman
Ya sure no problem. I bought my DX260 from Quebec Acoustic, their customer service was great.Hey Neighbor
I can not see flacs or can not reach music folder in sd card.
I am reluctant to perform factory reset since I don't want to setup everything from zero again. I don't use Mango app now. I use Mango operating system.
Same thing happened to me I was killing myself, like how can it work on Mango OS and not Android Mango Player….if this is the issue I was having….in Mango Player, hit settings and I didn’t know but you can SCROLL DOWN as you can’t even tell…and you can find the Scan Media option…here's hoping this is what your issue is…I can not see flacs or can not reach music folder in sd card.
Email Paul about that. Reset is a pain I know and I use Nuetron which sounds great but has a horrible interface and a real pain to setup again. That has to be a SD card and Mango issue. If you goto files app can you see all your music files? If you can't see them in files app its not a Mango issue.I can not see flacs or can not reach music folder in sd card.
I’m thinking he’s having the same issue I was having….on MangoOS you scan media…files pop up…now you go back to Android and you have to Scan Media Again, for the files to pop up on Android now…only issue with me is that for like 1-2 hrs I was killing myself cause I couldn’t find the Scan Media on Mango Player while on Android OS…on Settings you can’t tell you can SCROLL DOWN…I was going crazy lolEmail Paul about that. Reset is a pain I know and I use Nuetron which sounds great but has a horrible interface and a real pain to setup again. That has to be a SD card and Mango issue. If you goto files app can you see all your music files? If you can't see them in files app its not a Mango issue.
I wonder why that is happening. You can power off DAP and files stay. Just booting into mango OS should not change anything. I don't know where mango player stores that database file. That is a real pain. Sounds like something iBasso should fix.I’m thinking he’s having the same issue I was having….on MangoOS you scan media…files pop up…now you go back to Android and you have to Scan Media Again, for the files to pop up on Android now…only issue with me is that for like 1-2 hrs I was killing myself cause I couldn’t find the Scan Media on Mango Player while on Android OS…on Settings you can’t tell you can SCROLL DOWN…I was going crazy lol
Problem solved) I slided screen to right two times in Mango app and I saw folders of sd card.
Thank you all for helping me
Glad I could helpProblem solved) I slided screen to right two times in Mango app and I saw folders of sd card.
pietro77
- Mar 8, 2015
Anyone knows if battery is exactly the same as in dx240?
I have a nice deal on Penon Voltage if you will be interested.Hi,
You are right, at this price it deserves a better IEM. But I can't bring myself to spend so much on earphones
Anyway thanks for your recommandation![]()
