Hi,
Thanks for your proposition. I can't wait to find out the details (in private or here)
I LOVE Wavelet!! Use it all the time.Discount Sony z1R..
Thanks, I just updated without any issues. I am not sure if i needed to update, but I guess it cant hurt.New update. OTA
Updated succesfullyNew update. OTA
The Mango OS, not Android, is stripped down. To add the parametric EQ, further features are needed from Android so Mango will not have it.@Paul - iBasso, are you planning to integrate a parametric equalizer into the Mango OS? The existing one is very basic and is missing a lot of bands/parameters.
Otherwise, the DX260 is really really a good DAP![]()
Stay updated on iBasso at their sponsor profile on Head-Fi.
It won't break. Just use a dull instrument to put in. I use my fingernail. There is a spring in there that is tough and that is why there is resistance. If it gets stuck you can remove back cover and release it. T4 I think is the Torx you need. I took apart DX340 last night which is a bit more complicated than DX260.Is anyone having issues with inserting/retrieving SD cards? I've seen some YouTube videos on the subject and a post here and there. Currently can't insert SD cards without feeling like I'm going to break something. Have emailed ibasso but no reply (and the distributor where I live)...
What version? Mine doesn't receive any.New update. OTA
IF they upgrade OS it will be Android 13 which is what they should have done in the first place as DX180 came out 6 months later on Android 13. My guess is they might do it but not a priority. Maybe your country is blocking the update. Wait for Paul to come back. IF you have any issues you are SOL for 2 weeks. They will release a local update version too.What version? Mine doesn't receive any.
I still dream about Android 12+ update though
https://ibasso.com/dx260firmware/What version? Mine doesn't receive any.
