DX200=Affordable High End Audio. Dual ES9028Pro dacs. AMP1, AMP3, AMP5, AMP7 & AMP8 ***Firmware support now up for AMP9***
Sep 1, 2017 at 1:33 PM Post #8,102 of 22,021
I think I wrote it: changes in the firmware, not in Neutron.
But I wonder if the recent twit means Neutron will have implemented full support by itself... That would be much better!
We are working with Neutron and they are doing the changes so Neutron will be customized to the DX200. Full DSD and all resolutions.
iBasso Stay updated on iBasso at their sponsor profile on Head-Fi.
http://www.ibasso.com/ paul@ibasso.com
Sep 1, 2017 at 1:36 PM Post #8,103 of 22,021
Great news!! Will Neutron be incorporated into a FW update or does it need to be installed separately?
Sep 1, 2017 at 1:38 PM Post #8,104 of 22,021
Thanks for the info. So if you drain it down to 20% you are really only getting 6.4 hours playing time out of it.
When you are using the DX200 on the go use the battery to its fullest. If you are somewhere that it is convenient to charge it like work or home then it is good to charge it. You can use it plugged into the charger. If something is going to be stored I take the battery to 80%.
Sep 1, 2017 at 1:42 PM Post #8,105 of 22,021
You will go to the Neutron site.
Sep 1, 2017 at 1:52 PM Post #8,108 of 22,021
I really hope that the new Neutron that will be part of the working with iBasso will have a better GUI, I stand by my statement, the Mango experience is really good for the GUI.
I don't know about the GUI. You can contact Neutron and share your opinion.
Sep 1, 2017 at 1:52 PM Post #8,109 of 22,021
Sep 1, 2017 at 2:03 PM Post #8,111 of 22,021
Will they make adjustments to their user interface or just reprogram Neutron to work bit-perfect on the DX200? 'Cause Neutron's UI is quite ugly, especially compared to the Android Mango interface.
They are doing all the programing of the Neutron. For the UI please contact them and let them know what you think.
Sep 1, 2017 at 2:37 PM Post #8,113 of 22,021
Sorry to keep asking but...
Any news on getting Google playstore access (via official firmware)?
And can the DX200 ever be upgraded to support Bluetooth aptx via firmware?
Both are top of my wishlist and would make this DAP complete.
Sep 1, 2017 at 2:37 PM Post #8,114 of 22,021
I would but I cannot find any contact info or contact form on their website.
I let them know there are requests for a UI change/update.
Sep 1, 2017 at 2:44 PM Post #8,115 of 22,021
In all honestly, I am all with @HiFiChris here, I would probably be using Neutron more if it looked better. I am not in a position to offer help with that right now, but would be good if they changed their interfaces, they might even overtake some other APPs since they offer pretty good usability.
