Here is a more detailed picture process
1/ picture one.
The socket is cut at the plastic spacer and ring. Which exposes the inner grips of the L+ terminal
2/ picture two. Just the very little piece of foam that can flex back
circled in red as shown. I just push it into the space like the
illustrated as orange stuffing into that opening on the very top, the orange arrow pointed precisely toward the space to insert. You can see this little black foam I left on the side of the chassis.
Remember to plug and unplug your 4.4mm to make sure you feel it secure and easily remove just fine. Stuff in one small piece first to one side, test feeling it, then if needed add another to the other side
3/ picture three. Put back the Kapton tape for electrical insulation between terminal and the aluminum chassis cover. Done
@twister6 . Great idea, but I prefer a more real fix to the problem
