- Oct 6, 2013
I wasnt joking on how to fis this problem
How to fix your amp4 the original 4.4mm socket
1/ open up the amp. U will see this 4.4 socket
2/ the red arrows point to the last ring, and it is broken. Cut it off with some sharp wire cutter. Don’t worry, it doesn’t connect with anything
3/ underneath is the box illustrated in blue with a Vice U shape grib, and this is your L+ channel signal. It is weak, and cause intermittent sound cut off like what u described
4/ fix it by stuffing a flexible cut of sponge or foam in both sides (to help the grib clamp in better). Just stuff it, no need for adhesive. Test plugging your plug so it feels just right on plug and unplug. Not tigh or loose
5/ tape up the top with the kapton tape when u originally opened the amp up. Or else u can use electrical tap to insulate between the socket and amp chassis
Put together and done!
Or you can also get for under $2 one of these stick-on binder hole reinforcements to use as a spacer (on top of the headphone port)
